need advice with electronics - Jemsite
post #1 of 3 (permalink) Old 11-11-2012, 10:48 AM Thread Starter
im in need of help of deciding what kind of pots my guitar needs.i have a ibanez art100(les Paul body) and i don't know if i should get long shaft pots or regular strat kind.i also want to know what caps do and how they affect your tone.thanks
busgoeschoochoo is offline
post #2 of 3 (permalink) Old 11-11-2012, 11:41 AM
Re: need advice with electronics
i dont know that model in particular but i am going to say they are probably short shaft, The only way to know is check though.
As far as caps go, the larger the cap the more treble is cut out of the sound. Small vaule caps are used as a high pass filter like on the high end JS line of ibanez guitars.
You will probably want to go with .022 uf . You may want to play around with the vaule a little or add smaller caps in conjunction with the .022 to step up the vaule little by little.
Either way you go remember that ibanez.com has wiring diagrams, and you can also check out guitarelectronics.com for wiring diagrams.
if you need parts check out stewmac.com or smallbearelec.com
j.arledge is offline
post #3 of 3 (permalink) Old 11-11-2012, 11:43 AM Thread Starter
thanks man just what i needed
pots , transistor
Human Verification
New electronics oilpit JEM and Universe Guitars 4 05-12-2011 11:27 PM
AMT Electronics Nick83 Gear and Equipment 11 03-09-2009 01:53 AM
electronics wildchild247 Tech: Setup, Repairs and Mods 4 10-17-2005 04:07 AM
AMT electronics? jclogston Gear and Equipment 1 02-17-2004 06:42 PM
