Tech: Setup, Repairs and Mods
need help on jem
08-18-2002, 06:56 PM
Vai Timmons
Posts: 5 - iTrader: (
need help on jem
Hi I just ordered a JEM7V white guitar. I heard that it will have some action problems when it arrives. I want the action as low as it can go, with the factory setting will I need to adjust anything???What should I do when i get the guitar to make sure it has the lowest action, which screws need to be adjusted and turned etc.
Thanks
Vai Timmons
Find all posts by Vai Timmons
08-18-2002, 07:20 PM
Lonely Raven
Posts: 491 - iTrader: (
This is from that swirly banner near the top right of this page:
http://www.ibanezrules.com/tech.htm
Although I don't always agree with Rich on some things, he is a good guy
and has put lots of work into this hobby/job. He also sells some mean
axes!
READ AND LEARN!!
Lonely Raven
Visit Lonely Raven's homepage!
Find all posts by Lonely Raven
08-19-2002, 10:39 AM
nuno
Posts: 4,725 - iTrader: (
REMEMBER TO
LOOSEN
THE SET SCREWS BEFORE ANY HEIGHT ADJUSTMENTS!
nuno
Visit nuno's homepage!
Find all posts by nuno
08-19-2002, 10:48 AM
GhesQi J
Posts: 221 - iTrader: (
This site has also a very good "tech section",
a step-by-step guide for setting up your beloved 7vwh!
http://www.jemsite.com/tech/index.htm
And indeed, the factory settings aren't that good so the chance is great that you will have to setup the axe yourself.
Oh and BTW, congrats on your new axe !!
Cheers,
Joten
GhesQi J
Visit GhesQi J's homepage!
Find all posts by GhesQi J
08-19-2002, 11:04 AM
Vai Timmons
Thanks guys. If have any more questions or problems I let you know
Vai Timmons
08-19-2002, 12:24 PM
Gresh
Posts: 1,416 - iTrader: (
Hey welcome aboard and good to see another St. Louis person here. There's not too many of us around, me and rlintz basically.
Definitely go to the guitars section of jemsite and print the entire tech setup section. Then read it all the way through before doing anything. JEMs and UV's are a labor of love...difficult to get playing great, but once you do, nothing else compares.
Congrats on the new axe, enjoy.
Gresh
Find all posts by Gresh
08-19-2002, 12:33 PM
7 Dying Trees
Posts: 1,708 - iTrader: (
nuno
REMEMBER TO
LOOSEN
And I have a drill bit at home with half the post and insert welded to it at home to prove this point. Make sure, always! Me, my concentration lapsed for a second (heavy weekend) and I forgot about them...
Not good when the guy who's guitar you are setting up is next to you
Got it fixed though!
7 Dying Trees
Find all posts by 7 Dying Trees
08-19-2002, 12:41 PM
Vai Timmons
Will the jem come with a book to show me the different parts of he guitar and what they are called???? Im not sure what you mean by nuno wrote:
REMEMBER TO LOOSEN THE SET SCREWS BEFORE ANY HEIGHT ADJUSTMENTS
thanks
Vai Timmons
08-19-2002, 05:42 PM
GhesQi J
Again, Check the tech section:
http://www.jemsite.com/tech/t_1setup.htm#step2
tremolo bridge
height)
Where you can find a picture of the set screw.
Cheers,
Joten
GhesQi J
tremolo bridge
12:15 AM
