Tech: Setup, Repairs and Mods
Need help String sliding off fretboard!
01-30-2008, 10:17 AM
Kham
Posts: 32 - iTrader: (
I have a Japan Made fernandes revolver. Here are the pics. The Low Estrings dont line up well over the pickup and the frets its self. How would i fix this? Or is this normal? I just got into guitars with trems.
Kham
Find all posts by Kham
01-30-2008, 11:06 AM
moebius
Posts: 2,043 - iTrader: (
Re: Need help String sliding off fretboard!
If your guitar has a bolt on neck, you may need to loosen the bolts and try to push the neck laterally until the string lines up. I had a similar problem with the high e string on my RG 520. If you are new into guitars you may want to take it to a tech to have looked at.
moebius
Find all posts by moebius
01-30-2008, 11:11 AM
Kham
Yea its a bolt on. Its kinda got the all acess neck pocket like my ibanez rg470. Not new to guitars have used fenders and Gibsons for years and do all my own work on them. Just have never seen this problem iam new to floyd style guitars. Thanks for the help ill try it.
Kham
01-30-2008, 11:15 AM
moebius
If you are going to try it, just loosen the bolts a few turns and push the headstock down (or to the right if looking down the neck from the bridge). Then try to keep the leverage as you tighten the bolts. Good luck.
moebius
01-30-2008, 08:01 PM
ryanb
Posts: 1,457 - iTrader: (
Yes, but that only works if everything is aligned wrong -- i.e. the high e is too far from the edge and there is room to shift all the strings toward the treble side. In the pics, the high e looks pretty close to the edge of the board too (can't see it very well). It is largely personal preference, but it looks to me like the string spacing and fretboard width aren't very well matched on that guitar.
ryanb
Find all posts by ryanb
01-30-2008, 08:02 PM
Kham
I tried to push the neck did not even move a tad. So what else can i do. Is it the bridge post where drilled wrong. Or what else could it be?
Kham
01-30-2008, 09:08 PM
Dino
Posts: 1,721 - iTrader: (
That guitar doesn't look like it was designed for floyd spacing... or the neck is fron a different guitar. I would find whoever sold it to you and beat them with it.
Dino
Find all posts by Dino
01-30-2008, 09:14 PM
CosmicDebris
Posts: 3,216 - iTrader: (
Look in the circles and notice that the strings are way off center in the slots and if way off there it will be off on the fretboard. I would be intrested in seeing a pic of the bridge on the high E and B strings
The pic of the neck shows a WIDE string spacing. Either the other dude is right and that bridge is not meant for that guitar, your strings being off center on the pics will/could cause that, or possibly the nut is wrong also.
What model guitar is it?
CosmicDebris
Find all posts by CosmicDebris
01-30-2008, 09:15 PM
CosmicDebris
Also note in the pic that the strings that are centered in the bridge saddle line up correctly with the pickup.
CosmicDebris
01-30-2008, 10:20 PM
Kham
Its a fernandes revolver Japan made with sustainer. I got it cheap but neck is the one it came with it has a macthing headstock ill post a bunch of pics now.
Kham
Kham
Kham
01-30-2008, 10:56 PM
CosmicDebris
The
Low strings
are not in their saddles correctly as you can see the high in white are and are pretty much lined up correctly. Move the Strings to the center of the saddle and see how it looks then.
CosmicDebris
01-31-2008, 03:19 AM
Dino
Wow! Nice catch cosmic!
Dino
01-31-2008, 04:51 AM
Lefty Robb
Posts: 4,930 - iTrader: (
The low E looks like its in the slot OK though..just D and A are off..
Lefty Robb
Find all posts by Lefty Robb
01-31-2008, 09:42 PM
ryanb
The low E is off too (not as much). I noticed that earlier but it didn't look like that was the whole problem. From the new pictures, it definitely looks like the neck alignment is off. Obviously start by getting the strings in the right place in the saddles. But the original idea of shifting the neck should take care of it. Slightly loosen the
neck screws
and pull the neck toward the bass side. If it doesn't have any room in the pocket to move, you may have to trim a tiny amount off the neck pocket to give it room to move. When it is lined up, lock the neck screws back down. That should get it centered right.
ryanb
low strings
neck screws
how to make an LED fretboard
where to buy guitar string sin southampton
how to dye a fretboard
use a .016 for the 2nd string?
how to scallop a fretboard
LO TRS STRING SADDLE!!!!!!!! #2
zzzec
07:54 PM
zzzec
05:54 PM
Major Help! String Clamp Won't Budge!
Rekuss
07:57 PM
Yet another poorly mixed song by your truly
IbanezroadstarII
33
03-16-2006
10:01 PM
rg1527 seven string question
Jebus
06:38 AM
07:34 AM
