Tech: Setup, Repairs and Mods
Need Help w/Harmonics!!!
05-24-2007, 10:49 PM
kirk
Posts: 1,554 - iTrader: (
I've got a Gibson LP. At the seventh fret haronics are terrific, they sustain fantastically and sound great. However, at the fifth fret they are completely dead - muted.
Any ideas?????
kirk
Find all posts by kirk
05-24-2007, 10:58 PM
buddroyce
Posts: 1,914 - iTrader: (
Re: Need Help w/Harmonics!!!
Check your intonation
buddroyce
Visit buddroyce's homepage!
Find all posts by buddroyce
05-24-2007, 11:03 PM
jb4674
Posts: 4,010 - iTrader: (
Reviews: 6
How old are the strings?
Jimmy
jb4674
Find all posts by jb4674
05-24-2007, 11:12 PM
elcid
Posts: 8,718 - iTrader: (
Practice more
elcid
Find all posts by elcid
05-24-2007, 11:22 PM
kirk
I'll tighten up on the intonation, the strings ar relatively new - only about 2 wks. Keep suggestions coming please...
kirk
05-25-2007, 08:39 AM
neptoess
Posts: 303 - iTrader: (
like elcid said, it's probably your technique.
neptoess
Find all posts by neptoess
05-27-2007, 08:28 AM
kirk
elcid
Practice more
neptoess
oh, ok because it is so difficult to execute right?
kirk
05-27-2007, 08:59 AM
GilkyBear
Posts: 4,110 - iTrader: (
When you hit the harmonic, have you tried moving your finger a little back and forth over the spot a little each way and see if you can find it or is it just totally dead in the whole area? Also, are you cranking the distortion, that would definitely help find the spot.
GilkyBear
Find all posts by GilkyBear
05-27-2007, 09:06 AM
JJEMMER777
Posts: 8,374 - iTrader: (
kirk
Lol.....thanks for the morning laugh
I take it this LP is a NEW aquisition for you??
Since we've ruled out proper execution, lol:
Fret problem maybe? Raise up the action a tad (tweak the truss if need be) and see if you can't hit the harmonic
JJEMMER777
Find all posts by JJEMMER777
05-27-2007, 09:10 AM
Dee
Posts: 8,514 - iTrader: (
I can't see it being a fret problem! Harmonics have nothing to do with frets, so nay.
I've never seen anyone complain about not being unable to hit a harmonic at that point on the fretboard. Most strange!
Dee
Find all posts by Dee
05-27-2007, 10:22 AM
sugizo_esp
Posts: 446 - iTrader: (
Dee
well, harmonics got relation to perfect intonation..if your guitar is out of intonation, then some harmonics will sound muted.
and intonation relates to the frets if they are at correct measurements within the neck scales and so on
a properly set up guitar should get u perfect natural harmonics at ease
sugizo_esp
Visit sugizo_esp's homepage!
Find all posts by sugizo_esp
05-27-2007, 02:04 PM
neptoess
sugizo is right, if your guitars intonation is out the harmonic will no longer be right above the fret. check that
neptoess
05-27-2007, 02:07 PM
elcid
kirk
I dont know, I have 4
Les Paul
and have no problems playing harmonics on them
elcid
05-27-2007, 03:00 PM
Dee
sugizo_esp
Of course, but 5th fret harmonics should be easy to hit, even on a badly set up guitar.
Dee
05-27-2007, 10:03 PM
timi_h
Posts: 1,104 - iTrader: (
yeah its the 4th simplest mode of oscillation!
have you tried just picking rapidly and sliding your finger about an inch either side of where the harmonic *should* be so that you can find the right point? cos i can get that harmonic to ring out clear as day on a cheap as hell MANDOLIN!!!!
i suspect that you may just be putting your finger a little bit off from being dead over the 5th fret
(sorry i didnt mean my post to sound quite as patronising as it came out and i am trying to be genuinely helpful!!!)
timi_h
Find all posts by timi_h
les paul
neck scale
how to satriani harmonics
what string gauges a best for pinch harmonics
what does pick harmonics mean
how to play the harmonics for blurry
how to get pinch harmonics to come out good
07:39 AM
