Originally Posted by smasher2000
many thanks guys,
my woodworking skills should be fine although the body i've bought already has the routing done, only without the holes drilled for the posts etc so i'm just going to try and get a bridge that fits the dimensions of the routed section.
what makes an edge easier to fit than any other type of floyd?
Could you also advise on the neck setup? ive bought a 24 fret 25 1/2 scale neck that fits nice and snug to the body. Am I right in thinking that once i get the bridge set up and start fitting the neck that the distance between nut and 12th fret is exactly the same as 12th fret to "string saddle entry"?
I'm a little cautious about the little things i have to remember and the order in which i need to do things
Nothing makes it easier to fit than any other type of floyd as such, its just the shape of the unit and the way its built makes it really easy to look at it and say 'this does this, it goes there'
As opposed to some other bridges that are cosmetically awesome but have lots of parts that are easy to confuse.
Intonation is generally the distance from nut to 12th fret, times 2, and then with a little bit added on to allow for the
string stretching when you press it down. Its a good starting point, but there are scale length calculators you can use if you google them.
