NGD/Refinish - RG7620 to RG7CT "esque" Conversion - Jemsite
post #1 of 141 (permalink) Old 02-01-2011, 05:08 PM Thread Starter
Hello Everyone,
I have had this guitar for a couple of months now and I am in the process of refnishing it..
I actually put it through its paces for a good month before I started the refinish process.
Man... I don't know what took me soo long to get a 7 string... Even my cheeszzy Chuga Chuga riffs sound kweeel...
Anyways, the stock pups are not bad by any means but not as clear as some of my other guitars.. So I will be swapping them out with the LF/CL combo when it is all said and done...
I am pretty far along in the refinish and will post pictures every now and then..
As the title says I will be going for the RG7CT look.... and be using a venner top to do the sunbusrt
apadua is offline
post #2 of 141 (permalink) Old 02-01-2011, 05:15 PM Thread Starter
Re: NGD/Refinish - RG7620 to RG7CT "esque" Conversion
Disassemble
Sanding
I was surprised how the grain looked.. Was not expecting Basswood to look like this...
This will stain nicely....
apadua is offline
post #3 of 141 (permalink) Old 02-01-2011, 05:31 PM Thread Starter
Supplies
Staining the Body
After 2nd coat .. It is getting darker..
Doh... looks like I did not remove all of the sealer. You can see the light spots in the top left horn and the at the bottom...
apadua is offline
post #4 of 141 (permalink) Old 02-01-2011, 05:38 PM Thread Starter
Re-sand and stain again..
Look like a violin finish when the flash hits it...It is actually much darker..
Let dry overnight
All dry now
apadua is offline
post #5 of 141 (permalink) Old 02-02-2011, 01:41 AM
Reviews: 11
Cool man A veneer top would have been sweet, but I like what you are doing here. What are you using to top coat it?
linuxpenguin is offline
post #6 of 141 (permalink) Old 02-02-2011, 01:46 AM
Reviews: 98
I like it, but also think a figured veneer would have been really sweet on the top.
AlaskaBat is offline
post #7 of 141 (permalink) Old 02-02-2011, 11:36 AM Thread Starter
I am still going with a veneer top... Stay tuned
Hopefully, I can post more pictures later today..
I will be about 3 cans using Deft Clear for the top coat..
apadua is offline
post #8 of 141 (permalink) Old 02-02-2011, 12:28 PM
That is exactly what I'm thinking for my 1st project. Thanks for the pics. Now I know I'm not the only one thinking about this.
I would love to see the veneer in there too.
Keep posting pics man. I'm catching ideas here.
Scarified_pr is offline
post #9 of 141 (permalink) Old 02-02-2011, 12:36 PM Thread Starter
here is a little tease
apadua is offline
post #10 of 141 (permalink) Old 02-02-2011, 12:48 PM
Reviews: 11
looks sexy!
D.M.RG7620 is offline
post #11 of 141 (permalink) Old 02-02-2011, 01:38 PM
What kind of glue did you use to put the veneer on?
Do you have a template for the routing?
Did you route the first (holes and tremolo cavities) and then put it on the body or routed it once it was in place?
post #12 of 141 (permalink) Old 02-03-2011, 06:14 PM Thread Starter
What kind of glue did you use to put the veneer on? ?
I used Titebond II which I picked up from home depot..
Do you have a template for the routing??
No I don't.. But that is an EXCELLENT idea.. I should of made one out of construction paper or something... I have had issues cutting/routing the veneer.. It took me 3 tries to get it right.. Especially at $20 a pop it starts to add up...Since the Veneer is so thin you have to be carefull because it can split and crack if you are too aggressive with it...
IMPORTANT TIP: You want to do one side at a time. That way you have access to the cavities when cutting the veneer. You will need an exacta knife with plenty of replacement blades. I used 6 blades for this project.. Also DO NOT rush... I will be posting my mistakes later in this thread..
apadua is offline
post #13 of 141 (permalink) Old 02-03-2011, 06:41 PM Thread Starter
Prep for Sanding Sealer
Supplies
Deft Sanding Sealer, Tack Cloth
Wipe down body with Tack Cloth
After S&S:
You can see it looks kind of dusty/ashy.. Don't worry this will be gone after light sanding and when you apply the clear coat..
All Dry...
apadua is offline
post #14 of 141 (permalink) Old 02-03-2011, 06:48 PM
Where's the veneer? Are this previous pictures?
post #15 of 141 (permalink) Old 02-03-2011, 06:55 PM Thread Starter
The veneer in the earlier post.. was just a tease... I will be posting pics of that later in thread..
I took alot of pictures and want to post them in sequence... This will include the mistakes I encounter along the way.
apadua is offline
rg7620 , rg7ct , veneer
Human Verification
WTB: USED ECONOMIC DIMARZIO CLIPLOCK STRAP YJM "CHEETEH" OR "OCELOT" FINISHED crazyibanez Classified Ads: Guitars and Gear 3 04-12-2011 04:57 PM
"Jackson" Logo Neck Plate & SRV "Music Notes" Leather Strap muttznmongrelz Classified Ads: Guitars and Gear 0 06-12-2010 07:48 PM
ever see a "JS1000" with black gloss, no "satch" inlay and a "J" ser. # IKE560 JS (Satriani Model) Ibanez Guitars 2 04-11-2009 03:05 PM
rg7620 body + Dimarzio "New 7" pickups FS zar7 Classified Ads: Guitars and Gear 2 11-25-2008 10:12 PM
Enough intonation play in an Edge to do a "fake baritone" conversion? Randy G Tech: Setup, Repairs and Mods 0 08-05-2008 01:37 PM
