Old 02-03-2011, 07:07 PM
apadua  is offline
Posts: 596  -  iTrader: (5)
Re: NGD/Refinish - RG7620 to RG7CT "esque" Conversion
Veneer Prep
Line up the veneer so that the grain match/line up and tape it down
Find the center of the body and mark it
Line up the center of the veneer with the center of the guitar body..
Trace Body FACE UP . This will be important later....
Cut Veneer: Give yourself enough slack....you can cut off the excees with an exacta blade later
Old 02-03-2011, 07:18 PM
apadua  is offline
Whaabaam!!!
Gluing down the Veneer
Wipe down the body with Tack Cloth
I used Titebond II wood glue and used a foam roller to apply it
Put the glue on both the veneer and body
Spread the glue with roller so that it is nice and even (not pictured)
Flip the guitar over and put some kind of object (I used a bag of rice) to apply pressure and let dry for at least 3 hours...
All Dry..
Old 02-03-2011, 07:24 PM
apadua  is offline
MISTAKE #1
Without even thinking I proceeded to the other side.. I did not realize that by doing this would block the access to cut the cavites for the pups and trem.... Below are some pictures.....
Applying pressure to the side with the coutour is a bit tricky.. So I used a combination of the rice bag and my wife's fashion design binders to apply the weight... Also the body is facing up...
Old 02-03-2011, 07:33 PM
apadua  is offline
Mistake # 2
I rushed through cutting the excess of the veneer.. At first I was using the exacta blade then got lazy and started to use my fingers..
I bent the veneer back and forth against the body and broke it off.. It actually broke off pretty cleanly in most places... But the places that did NOT break off cleanly look horrible..
I can not stress enough to "Take your time" and Absolutley do NOT Rush... This by far the most time consuming and tedious part of the process..
Eewwwww...
Jagged Edges
Since I put both sides of the Veneer on before cutting.. I had to poke a hole in the middle of the cavity to get started on the trimming... As you can see from the pic below a section of the veneer came off while trying to poke the hole...
Old 02-03-2011, 07:38 PM
RGTFanatic  is offline
Posts: 6,111  -  iTrader: (14)
Images: 3
If you have a high speed router, you can use a flush cut bit with a bearing on it to cut out the recesses. something like this:
Old 02-03-2011, 07:41 PM
apadua  is offline
Veneer Removal
Any Iron with steam will do the trick... Well Kinda...
The steam worked for a little bit but once the veneer started to crack it was useless..
I had to resort to using a screw driver to get it off...
Messy, Messy, Messy
Old 02-03-2011, 07:47 PM
apadua  is offline
Re-Sand Body....
Re-Stain Body....
Which was not really necessary since another veneer would be going on top...
Images: 3
sorry... this would actually be the correct bit...... the bearing rides on the body and cuts everything perfectly flush.
Old 02-03-2011, 07:50 PM
Images: 3
BTW.... (not being a smart ass) Why are you staining the top?
Old 02-03-2011, 08:06 PM
apadua  is offline
Veneer # 2
Line up/"Book-match" grain...
MISTAKE # 3
Ok this was another not so great idea.. The first time I traced the veneer with guitar facing up IT left some pencil marks from the tracing after I cut it...
So I thought ...hey... the next go around I should trace the body face down... FAIL!!!
This made the veneer to small when I when laid it back on the body...
Again....
DO NOT TRACE THE VENEER WITH THE BODY FACING DOWN!!!
Old 02-03-2011, 08:12 PM
apadua  is offline
I wasn't sure how much of the edges would be sanded off and.. I suppose I could of just restained the edges after the veneer was in place...
I also had extra stain laying around
Old 02-03-2011, 08:17 PM
apadua  is offline
VENEER # 3
Third time is a charm...
This should start to look familliar now...
BTW... This is not enough glue.. I actually put more after I took the pic..
One Side at a time... After you glue down one side
STOP and cut the cativies then move on to the other side (NOT Pictured)
Taaaa Daaaa
Old 02-03-2011, 08:22 PM
apadua  is offline
The edges have been sanded off and came out pretty nice...
CHIPS and Blemishes
Obviously, I am not a pro.. and this my 2nd refinish and first time time working with a veneer top.. So Unfortunately, there were some chips from the cutting...
Old 02-03-2011, 08:27 PM
apadua  is offline
Before Touch-ups...
Touch-ups
I had some left over scraps from cutting off the excess.. So I cut tiny peices the best I could and filled in the chips..
All filled in
Old 02-03-2011, 08:28 PM
Images: 3
looking very good.... this top looks a lot nicer than the first one
rg7620, rg7ct, veneer
WTB: USED ECONOMIC DIMARZIO CLIPLOCK STRAP YJM "CHEETEH" OR "OCELOT" FINISHED crazyibanez Classified Ads: Guitars and Gear 3 04-12-2011 04:57 PM
"Jackson" Logo Neck Plate & SRV "Music Notes" Leather Strap muttznmongrelz Classified Ads: Guitars and Gear 0 06-12-2010 07:48 PM
ever see a "JS1000" with black gloss, no "satch" inlay and a "J" ser. # IKE560 JS (Satriani Model) Ibanez Guitars 2 04-11-2009 03:05 PM
rg7620 body + Dimarzio "New 7" pickups FS zar7 Classified Ads: Guitars and Gear 2 11-25-2008 10:12 PM
Enough intonation play in an Edge to do a "fake baritone" conversion? Randy G Tech: Setup, Repairs and Mods 0 08-05-2008 01:37 PM
