Old 05-12-2009, 02:13 PM
ShellyOFG  is offline
Posts: 133  -  iTrader: (0)
No sound.. uh oh
Okay, i've got a JCRG 1702 it has a H H configuration with a 5 way toggle.
Now my guitar worked fine last week and then the volume and tone pots became quite loose, however it was fine for about 2/3 days and then suddenly i plugged in my guitar and got no sound at all.
I figured maybe it was something to do with the knobs being loose, so i tightened them but no dice i'm afraid. So i've come to a conclusion that there could be a pickup wire loose somewhere. Neither pickups work. I haven't taken the back off and had a look yet as i am definately no expert at guitar electronics.
There is a local store i can take it to for repairs however i use my guitar every day for music college! Any suggestions guys? Much appreciated
Old 05-12-2009, 02:36 PM
moebius  is offline
Posts: 2,041  -  iTrader: (0)
Re: No sound.. uh oh
Pull off the back plate and see if you can locate a wire that is not connected.
Old 05-12-2009, 02:42 PM
Im trying now, the screws are REALLY REALLY tight.
Old 05-12-2009, 02:53 PM
EDIT: Okay found 2 loose wires, a white and a black one. When i touch the white one to the metal part under the toggle switch I get sound ! Not sure what the black one is for... I guess i need to solder it ?
Old 05-12-2009, 03:01 PM
moebius  is offline
Get a wiring diagram from Ibanez website and it will show you where the wires should be soldered.
Old 05-12-2009, 06:24 PM
nsabino  is offline
Posts: 463  -  iTrader: (0)
WTF, how old are you, 2? Get a tire iron if they're that tight, he,he,he.... of course you need to solder those wires, although if I were you I'd be really careful not to set the guitar on fire when soldering.....
regards
Old 05-13-2009, 03:31 PM
Or perhaps the back has never been taken off ? and perhaps i had a really ****ty screwdriver? WTF? How dumb are you ? ... not necessary
Sound Clip: How do I get my JS-1000 to sound like this? DMTransmutation JS (Satriani Model) Ibanez Guitars 7 03-08-2009 09:41 AM
How do I get this sound? CityofBlindingLights Pickups & wiring 4 12-03-2007 11:43 PM
how does this mix sound? {mp3} JimmyJ Multimedia: Music, Pictures & Sounds 6 07-11-2006 11:21 PM
How does Vai get his sound? JimmyJ Gear and Equipment 11 11-13-2004 11:11 AM
Is the sound on an old paf pro better?? jawi88 Pickups & wiring 14 08-09-2003 06:47 PM
