Old 12-29-2012, 03:02 PM
RGTFanatic  is offline
Posts: 6,096  -  iTrader: (14)
Images: 3
Re: Nut Height
Originally Posted by Ericson View Post
The buzz is just about killing the note, standard .009 guages, the bridge is level to the body - it's not that hard to see if it's level or not.
OK, so it sounds like your close to your "perfect" setup.
There are several possible reasons your low-E is buzzing/fretting out.
The slot on the nut for the string is too deep/worn out?
You may need a little shim on the low-E side of the nut?
You may need a fret level and dress? If the second fret-wire is higher than the first, it's going to buzz.
You may want to try another set/brand of strings? I've had EXCELLENT results with Kurt Mangan strings.
You may have scarf joint shrinkage which will cause a slight back bow from the first to third frets.
You may want to raise your trem on the bass side a slight bit. Level (as viewed from the rear of the trem) is not necessary, playable is.
Did you shim the neck? if so do you have pics of how you did it??
__________________
Old 12-29-2012, 11:55 PM
Ericson  is offline
Posts: 27  -  iTrader: (0)
Re: Nut Height
It's the frets, How can I "level and dress" them? Yes the second fret is higher than the first, very very weird...
Old 12-30-2012, 02:55 AM
LonePhantom  is offline
Posts: 7,199  -  iTrader: (8)
Reviews: 120
Re: Nut Height
The fret might have popped a bit. Can anything fit under the fret? Clamp it back in and see if it holds if its raised. If not you might need a small amount of super glue to help hold it.
Old 12-30-2012, 04:22 AM
dimitar  is offline
Posts: 529  -  iTrader: (1)
Re: Nut Height
I can use a rubber hammer to tap on the higher fret a little
and this could help to put it back on the slot.
Old 12-30-2012, 04:34 AM
Rich  is offline
Posts: 20,368  -  iTrader: (21)
Re: Nut Height
It's most likely scarf joint shrinkage pulling back on the nut.
Old 12-30-2012, 05:14 PM
Ericson  is offline
Smile
Re: Nut Height
so Rich how do I fix that?
Old 12-30-2012, 05:24 PM
Images: 3
Re: Nut Height
Get a fret level and dress done............ Any luthier worth his salt can do it.
Where are you in MI?
__________________
Old 12-30-2012, 06:51 PM
Rich  is offline
Re: Nut Height
Humidity [rehydration] only helps as long as it will remain in constant humidity, so it's not the right fix. The right fix it to cut it.
Old 12-30-2012, 09:11 PM
Ericson  is offline
Re: Nut Height
Kalamazoo
Old 12-31-2012, 06:18 PM
Images: 3
Re: Nut Height
cut what?? You lost me........ as usual
__________________
Old 12-31-2012, 06:21 PM
Images: 3
Re: Nut Height
Kalamazoo
$80 for a complete level and dress.......pretty much the standard rate. You should point out the scarf joint pulling down frets 1 and 2 so the luthier knows what he's working with.
http://chartersguitars.com/repair.php
__________________
Old 01-01-2013, 07:31 AM
Rich  is offline
Re: Nut Height
cut = level
setup
Nut Height? Stormcrow Tech: Setup, Repairs and Mods 5 09-28-2005 05:28 AM
EMG Height question Jslegacy Pickups & wiring 4 05-19-2003 11:32 PM
Height on EMG's? big h Pickups & wiring 1 04-23-2003 03:22 PM
String height on my UV Wadstein Tech: Setup, Repairs and Mods 3 01-15-2003 11:03 AM
PU height on EVO and FLO pri0531 JEM and Universe Guitars 4 02-06-2002 10:28 AM
