Old 11-28-2002, 12:17 AM
stratman219  is offline
Posts: 283  -  iTrader: (0)
nut lock down screw
on my new rg 570, when i try to tighten the nut lock down screw(i'm refering to the screws on the back of the neck that hold on the nut) i tighten it and i can feel the tension of the screw getting harder, but after i can keep turning the screw, i don't think its stripped because it can come back out. i know this can cause tuning problems, but i have bad knife edges that i need to fix so i don't know if it will effect the tuning. is it normal for the screw not to stop when tightening?
Old 11-28-2002, 05:45 AM
Project Guitar  is offline
Posts: 979  -  iTrader: (0)
Might want to pull the block assembly off if you get a chance and see if it isn't stripped, sure does sound like one or the other is...........
Old 11-28-2002, 11:27 AM
nuno  is offline
Posts: 4,725  -  iTrader: (0)
try swapping the two screws, to see if is the screw stripped, or the nut.
but i wouldn't worry as much, as long as you have the other screw working. if you say the 'stripped' screw tightens, even if doesnt stop turning, well, no problem.
