Old 02-26-2007, 04:37 PM
Satchriossi  is offline
Posts: 294  -  iTrader: (1)
nut shim material
What do you use to shim the nut on guitars you've had that needed adjustment in this area? There isn't enough of that thin shimming metal under the nut of my latest aquisition and i wondered what others did when they encountered the same problem?
cheers
Old 02-26-2007, 04:49 PM
JJEMMER777  is offline
Posts: 8,374  -  iTrader: (5)
Re: nut shim material
Aluminum cans work great
And FYI - Beer cans are classier than soda cans
Old 02-26-2007, 06:23 PM
Ironjose  is offline
Posts: 1,056  -  iTrader: (0)
is the aluminium to thick? or not?
Old 02-26-2007, 08:43 PM
LonePhantom  is offline
Posts: 5,360  -  iTrader: (6)
Reviews: 98
Emery paper works well for shimming as the course grainy side helps the connection between the two surfaces. Good for locking nut shims and neck joint shims.
Old 02-26-2007, 08:57 PM
Ironjose  is offline
since we are talking about shims, what should i use for shimming a saddle especially the 6th string on a radius guitar? (is it well writen?)
Old 02-26-2007, 11:18 PM
Racerx2k  is offline
Posts: 1,076  -  iTrader: (0)
Sandpaper works well.
Old 02-26-2007, 11:23 PM
crevis  is offline
Posts: 2,599  -  iTrader: (1)
Something I used to do is cut up some post its, start with too many and remove them one at a time until it's at the right height.
Old 02-27-2007, 08:55 AM
waylay00  is offline
Posts: 3,763  -  iTrader: (10)
I use sandpaper, as Racerx2k said.
Old 02-27-2007, 06:55 PM
Ironjose  is offline
i use sandpaper on my peavey's nut, but i think its to thick? or maybe i'm wrong? what material does ibanez uses for shimming?
Old 02-27-2007, 08:06 PM
Racerx2k  is offline
Actually, if you normally switch to a finner grit, you will get a thinner shim. Try that, Jose, if you think your sandpaper shim is too thick.
Old 02-28-2007, 05:56 PM
Ironjose  is offline
hmmm that never crossed my mind... i will try that...
locking nut, neck joint, nut shim
Nut shim material? waylay00 Tech: Setup, Repairs and Mods 7 10-18-2008 01:31 AM
Neck Shim Materials Gex Tech: Setup, Repairs and Mods 7 07-27-2006 02:21 PM
Do I need a neck shim? giannifive Tech: Setup, Repairs and Mods 8 02-10-2005 04:39 PM
Nut shim...Any material? burt777 Tech: Setup, Repairs and Mods 13 08-02-2003 02:30 AM
How many times can you shim the neck? Triangle Tech: Setup, Repairs and Mods 16 07-30-2002 12:38 PM
