Originally Posted by 0americana
im not saying higher action
like
if you tied a pice of string to 2 trees
and the wedged it inbetween like a nut would
surely the string would get tighter?
Oh, I see what you're trying to say...
No, because pitch is a function of string tension. In the above scenario, if you started with the "nut-like" wedge between the two trees with the string at a certain pitch, and then pushed the "nut" up a couple inches, then yes, the string would increase in tension. however, it would also now be pitched higher. If there was a "tuning peg" atttached to one of the trees, and you plucked the string, you would notice you were now tuned sharp by rather a lot. So, you would detune the string until you were back to the correct pitch. Your string tension would now be exactly where it was at the beginning of this thought experiment, where the nut was in contact so as to set the vibrational length, but wasn't adding any additional tension.
So, basically, none of this matters because if you're nut magically got higher, you'd have to retune anyway.
