Tech: Setup, Repairs and Mods
Odd Buzz
03-05-2003, 09:25 PM
BREWTAL*LICKS
Posts: 92 - iTrader: (
Odd Buzz
I have a strange sustain killing buzz when I do a full bend on the 16th fret of my high e string. Could this be a sign that the frets need to be filed?
cheers!
p.s. Every other fret is fine, so i'm sure it has nothing to do with my
bridge saddles
or the
neck position
. But then again, i'm an idiot!
BREWTAL*LICKS
Find all posts by BREWTAL*LICKS
03-06-2003, 08:35 PM
Champagne Mist
Posts: 153 - iTrader: (
Not sure if this is the problem, but are your strings old? If i play my strings till they're pretty worn, the high e always loses sustain in the
upper frets
. When amped, it has this "oscillating" sound. really wierd.
Champagne Mist
Find all posts by Champagne Mist
03-06-2003, 09:10 PM
BREWTAL*LICKS
Nope. This has been going on for quite a while. I change my strings regularly.
cheers!
p.s. This effect ONLY occurs on the 16th fret. Not above or below the given point.
BREWTAL*LICKS
03-06-2003, 09:16 PM
Posts: 19,344 - iTrader: (
Sounds like 17 is a tad high right at the spot the string ends up in the bend. Check the clearence off the top of the 17th, then bend the 17th and check the clearence off the top of 18 to determine if 17 is high or 16 is low. Ultimately a level will solve it, but if it's just one fret that a little high [and it won't affect 18] you can do a little spot sand on that one fret to clean it up.
03-06-2003, 10:42 PM
BREWTAL*LICKS
Hey, thanks man. I'll check it out now.
cheers!
BREWTAL*LICKS
bridge saddles
neck position
upper fret
upper frets
how to fix low e buzz
is slight fret buzz ok?
how to intonate a buzz feiten yourself
how to get rid of string buzz
how much frett buzz is ok
02:15 PM
