Old 11-06-2009, 12:47 PM
jbandy10  is offline
Posts: 139  -  iTrader: (0)
Odd sized truss rod nut
I have an Ibanez RG550 from 93' that has apparently decided it doesn't want the truss rod nut to fit anything.
In the past I remember tweaking it with some arbitrary size but I decided to set it up again yesterday I grimly realized that it wouldn't take anything I gave it.
Started with my team J craft tool. WAY too big. Then I moved to my socket wrench collection. I finally realized that my 7.5mm socket was too small yet my 8.0mm socket was too big. Obviously I don't have a 7.75mm socket and I don't know where to get one.
WTF do I do? This thing has a little bit of bow and I wanna fix it.
Old 11-07-2009, 12:21 PM
andrewgosline  is offline
Posts: 312  -  iTrader: (0)
Re: Odd sized truss rod nut
is it definitely metric? 5/16" inch is inbetween those two at 7.9mm, and it's a commonly available socket size
Old 11-08-2009, 01:37 AM
jbandy10  is offline
5/16 didn't fit either...
Old 11-11-2009, 01:56 AM
sirshredsalot  is offline
Posts: 435  -  iTrader: (23)
Reviews: 18
I have a 91 550. I use a standard wizard truss rod wrench that i bought from rich, not sure the exact measurements.
Old 11-20-2009, 10:49 PM
spudler_t  is offline
Posts: 75  -  iTrader: (0)
Reviews: 12
I have a 94 RG550 LTD neck and the 7MM works for mine. are you sure it is not the angle that is messing with you?? I had to put my socket on then insert my extension. I use a 1/4" drive and extension. If I try to do it with extension on it acts like it is to big for socket. maybe try a 9/32 or 11/32 one is smaller then 5/16 the other is bigger. 9/32 is 7.144 mm 5/16 is 7.938 mm and 11/32 is 8.731 mm. Depending on what quality of tools you have.
Single-coil-sized humbucker Shredder87 Pickups & wiring 3 07-28-2008 03:11 AM
Single Sized Hum For Instrumental Rock Thrash Pickups & wiring 5 07-06-2008 06:23 PM
Humbucker sized p-90 Jeremiah Pickups & wiring 13 11-28-2007 08:48 PM
Single Sized Humbucker ? Thrash Pickups & wiring 13 08-14-2006 12:51 PM
PAF pro and single sized similars. urkoman Pickups & wiring 4 01-15-2003 08:24 AM
