i am sure this has been talked about enough already, but i want to put in an Original
FLoyd Rose bridge into my RG320. it has a lo-trs II now. i know an original edge will fit. i have an older 570 that has an edge. the rout in the 320 is a litte larger.
reason being is that i use alot of Drop D tunings and the lo trs, even if i have the fine tuner all the way down won't drop to D. i wanted a bridge that i can put an EVH D-tuna on.
It has been said here that an OFR will work without any mods. i don't use the whammy bar on my trs much anyway. i use my edge for that.
if i put the d-tuna on, about how much farther will the bridge tilt forward?
Is it worth trying?
