Re: Old style RG neck with overhang question.
Besides a refret and leveling of the board, taking those frets down is probably your only option. It does occur to me that a temporary solution might be to drill through your 24th fret inlays, and put in two small screws (countersunk flush) custom tightening them so as to pull the fretboard extension down toward the body. There's obviously enough relief in the body to accomodate the extension. You shouldn't crack anything because the wood moved on it's own from "point zero" when it was manufactured, so you are just moving it back, not over-bending it. See if you can fret a note, while holding the board extension down, and if there's enough play in there to easily do it. Later on down the road, when it's refret time, just replace the inlays.
