Tech: Setup, Repairs and Mods
Open string buzzing
Page 1 of 3
08-29-2002, 10:37 PM
eg
Posts: 259 - iTrader: (
Open string buzzing
I have an RG470 with a LoTRS Trem. I've been having some problem with my open lower E string.
When its played open, I get some kind of vibrating sound, like a wire vibrating and knocking against some metal. However, fretting the string any where would eliminate the sound.
I tried listening really carefully and somehow think that it is coming from the trem cavity maybe somehwere below hte string saddles.
This vibrating sound can sometimes be heard on the amp as well; thats why I'm trying to eliminate it.
Other strings are fine and do not have this problem.
Anybody has any ideas? Else I would just have the technician look at it when I get my strings changed the next time.
eg
Find all posts by eg
08-29-2002, 10:41 PM
Two hands31
Posts: 4,989 - iTrader: (
Sounds like the open string (wire) hitting the first fret (metal). This would be stopped by fretting because it's pressed against this fret, or one beyond it anyways.
Two hands31
Visit Two hands31's homepage!
Find all posts by Two hands31
08-29-2002, 10:43 PM
eg
Well.. this buzz sounds totally different from a normal
fret buzz
because I have do have some slight buzz on the lower E and the sound I'm describing is actually more metallic.
eg
08-29-2002, 11:54 PM
Two hands31
Hmm....loose part? Maybe one of the tuners? (try wiggling them, parts of the bridge, nut, anything that could possibly become loose)
Two hands31
08-29-2002, 11:57 PM
musicdr
Posts: 671 - iTrader: (
Check for loose screws,especially
strap button
,and the base of the tremolo block screws.Check all of them.If its not that loosen the
truss rod
a 1/4 turn.Check the setup pages here on jemsite.
musicdr
Find all posts by musicdr
08-29-2002, 11:58 PM
Posts: 19,350 - iTrader: (
Check and see if it's a spring ocsillation causing the noise, mute them with something, hand, pillow, etc.
08-30-2002, 12:02 AM
Two hands31
And once you've figured out how to play guitar AND hold the springs at the same time (assuming you're using your third arm) you can tackle
this
Two hands31
08-30-2002, 12:03 AM
It's an open string buzzing, look, no frethand Ma
08-30-2002, 12:04 AM
Two hands31
Ok, so when you can figure out how to move your left hand to the back of your guitar before picking that open string, then back to the neck again fast enough...
Two hands31
08-30-2002, 12:06 AM
It's just to check, if that's the problem the fix doesn't require your other hand
08-30-2002, 04:59 AM
eg
yeah i''ll try that tonight....
eg
09-02-2002, 09:34 PM
eg
I unlocked the locking pad for the low E and A and the sounds went away and they came back when I locked them in again. Funny, this sound occurs for the low E string only.
Advice anyone?
eg
09-02-2002, 10:00 PM
sniperfrommars1
Posts: 3,302 - iTrader: (
Yeah
Its definitely at the headstock. Maybe your string retainer isnt down far enough? Might be rattling around back there when the headstock is going crazy, could also, be a
nut shim
, or do you might have your
locking nut pads
turned around the wrong way, ie, they shouldnt be in a straight line
sniperfrommars1
Find all posts by sniperfrommars1
09-03-2002, 01:25 AM
eg
I'm kinda new to guitar stuff. Mind explaining in more detail
Thanks
eg
09-04-2002, 03:23 AM
eg
Hello??
eg
Page 1 of 3
floating trems
fret buzz
locking nut
locking nut pads
nut pads
nut shim
strap button
string saddle
truss rod
convert 7 string to 6 string?
where to buy guitar string sin southampton
what distortion pedal can take guitars string 10-60
use a .016 for the 2nd string?
jpx 7 string?
05:39 AM
