Old 01-19-2002, 10:55 PM
Captain Ron  is offline
Posts: 67  -  iTrader: (0)
Original Bolt On neck put on AANJ body? Rich? - is it possib
Hi, I wanted to know if you can take a neck thats original bolt on, lets say a fender strat, and get the neck fixed and put it on an ibanez AANJ body like a jem?
for instance, I have a fender strat, I want to take the orignal bolt on style neck off the fender. Sand/chop/modify the bolt on attachment part so it can fit AANJ neck system, and get a jem body, and put the fender neck on it
is it possible to do this?
and is it possible to just buy a jem7vwh or any jem body w/o the neck and w/o any electronics,
just the lo pro edge trem?
thanks
(Edited by Captain Ron at 10:07 pm on Jan. 19, 2002)
Old 01-19-2002, 11:09 PM
jemsite  is offline
Administrator
Posts: 9,271  -  iTrader: (5)
Images: 11
Captain Ron on 9:55 pm on Jan. 19, 2002
No. it is not practical to do this on an AANJ ibanez. Would work great with the original heel joint.
for instance, I have a fender strat, I want to take it off the fender. Sand/chop/modify the bolt on attachment part so its an AANJ neck, and get a jem body, and put the fender neck on it
first, you'd need a 24-fret 25.5" scale strat neck. Then, you'd have to modify the fender neck to have the same pocket dimensions as the Ibanez neck (not tough) then fill in under the fretboard if necessary... sort of what i did with this old-style JEM neck.
and is it possible to just buy a jem7vwh or any jem body w/o the neck and w/o any electronics?
not from ibanez.
you can buy this from ibanez dealers.
Old 01-19-2002, 11:18 PM
thanks glen, so basically
it IS possible, but not recommended, would it be easier if i had a 24 fret 25.5" original bolt on neck?
Old 01-19-2002, 11:19 PM
jemsite  is offline
Administrator
Images: 11
exactly ...glen
Old 01-20-2002, 02:02 AM
Project Guitar  is offline
Posts: 979  -  iTrader: (0)
Not to mention that the scale the neck is set up to be would be of simply because the first fret would not be the correct distance from the bridge when mounted.
I've had people ask me about modifiying a standard neck pocket to accept a AANJ neck, that will work but like Glen said the opposite is plain and simply a bad thought.
(Edited by becalvert at 1:04 am on Jan. 20, 2002)
Old 01-20-2002, 06:44 AM
Jeroenn  is offline
Posts: 873  -  iTrader: (1)
I did wonder about the other way around, like you mentioned Brian. And I know it has been done (Flo), but I'm kinda scared that the body there is just too thin (jem body) to make a strong joint.
Old 01-20-2002, 12:05 PM
Two hands31  is offline
Posts: 4,989  -  iTrader: (0)
Ok, all questions have been answered but one: *Why? *A Strat neck on a Jem?? *:shudder:
Old 01-21-2002, 07:14 AM
7 Dying Trees  is offline
Posts: 1,708  -  iTrader: (4)
What about 7string (old UV bolt on) necks? Can they be modded to fit an AANJ body? Or will the neck not be strong enough? I have wanted to get this done to a UV neck, but am not sure if it's possible.
aanj neck, edge trem, fender strat, ibanez dealer, ibanez neck, jem neck, pro edge, pro edge trem, standard neck
