Tech: Setup, Repairs and Mods
Original Edge, how to tighten the tremolo arm so it stays?
07-14-2007, 03:56 AM
trademe900
Posts: 46 - iTrader: (
Hi,
I am new to the original edge tremolo. Could someone please tell me how i can give the
tremolo arm
more torque so it can stick in the position i put it... rather than swing loose...
Thanks.
trademe900
Find all posts by trademe900
07-15-2007, 07:38 PM
standing8count
Posts: 280 - iTrader: (
Re: Original Edge, how to tighten the tremolo arm so it stays?
Change the little white bushings on the arm.I think Rich Harris sells them go check his site out (top of the page)
10:26 AM
standing8count
Find all posts by standing8count
07-16-2007, 03:10 AM
ohioplayer
Posts: 265 - iTrader: (
MF sells them pretty cheap too.
ohioplayer
Find all posts by ohioplayer
07-17-2007, 10:08 AM
jwoods986
Posts: 378 - iTrader: (
First, make sure there are two bushings on the arm. Obviously if one (or both) are missing, it will be loose. If both are there, then they are worn out and need to be replaced. I'm actually on the other side of the fence with this. I prefer a looser arm and am going to remove one of the bushings to see how I like it.
jwoods986
Find all posts by jwoods986
07-17-2007, 04:47 PM
CrossingStar
Posts: 1,046 - iTrader: (
If the
arm holder
is not loose you can tear off some plastic grocery bag material & wrap it around the end of the arm then shove it in the holder. a temp. fix.
CrossingStar
Find all posts by CrossingStar
07-18-2007, 03:52 AM
Jaden
Posts: 2,464 - iTrader: (
also make sure that the arm does not need tightening at the rear, you need a 10mm deep reach socket to tighten, I also use a little threadlocker on that thread becausseit comes loose easily.
Jaden
Visit Jaden's homepage!
Find all posts by Jaden
07-18-2007, 04:26 AM
markg5150
Posts: 2,361 - iTrader: (
do a search there are a billion berjillion threads on this
markg5150
Find all posts by markg5150
07-19-2007, 05:19 PM
trademe900
umm ok i just got this guitar like a week ago... rg550 20th... and yeah ive already replaced the bushings and within like 3 days it has become loose again... does not hold position.
One thing to note though, it seems to be inconsistent... like sometimes its stable.. sometimes not.. if i turn the trem bar in circles, it starts to grip sometimes and then it will go loose again... as if its moving the little bushings around... or something?
Surely it cant be the bushings? this is the second set within a week... and now it barely holds... unless i start turning it in circles until it grips again...
trademe900
07-19-2007, 09:41 PM
standing8count
whatisshredding
Then do what he says
standing8count
07-23-2007, 07:33 PM
trademe900
what exactly is a deep reach socket??
trademe900
07-24-2007, 03:57 AM
ShredHead42
Posts: 344 - iTrader: (
Or replace the arm with a
floyd rose
one. I recommend it over changing your bushings (or grocery bag, as i found more realistic) every 2 weeks.
there's a thread here:
http://www.jemsite.com/forums/showthread.php?t=34038
03:59 AM
. Reason: added link
ShredHead42
Find all posts by ShredHead42
arm holder
edge trem
floyd rose
tremolo arm
Original Floyd Rose into Edge III Cavity?
how to measure tremolo to scale
what metal is edge 3 tremolo made out of
how to setup an edge 3 tremolo
Edge mysteries solved!!......? - Answers to some common ques
Jason Stone
09:35 AM
What is good angle of edge pro tremolo?
Zelman
03:58 AM
Original Edge on Universe... - Good or bad thing??
UVmanMike
08:35 PM
UVmanMike
11:31 PM
Lo-pro edge into an original floyd rose cavity - Is it possi
Captain Ron
02:28 PM
10:20 AM
