Old 01-26-2007, 12:40 AM
bcgvh  is offline
Posts: 18  -  iTrader: (0)
Original floyd rose and string height?
Is there a way to change the height of each individual saddle on the original floyd rose? I just had it installed on my new homemade guitar and my overall string height is fine, but the B string is higher than the G and high E strings to where it makes it slightly uncomfortable and difficult when moving back and forth between those strings. I don't see a way to tweak this, am I missing something here? From what I can tell you can only change the overall height by raising or lowering the 2 outside pole pieces?
Old 01-26-2007, 01:08 AM
SonataGuitarist  is offline
Posts: 408  -  iTrader: (2)
Re: Original floyd rose and string height?
Your not missing anything, your right, you can't adjust individual saddle heights on the OFR, sorry.
What you could do is shim the rest of the saddles to match, and then lower the bridge action, but thats a pain in the ass imo.
Old 01-26-2007, 01:10 AM
Rich  is offline
The saddles are different heights. It's quite possible the b and g got swapped.
Old 01-26-2007, 03:31 AM
slash  is offline
Posts: 62  -  iTrader: (0)
Reviews: 8
I agree with Rich. The saddles are different heights. The G & D saddles are the tallest while the E saddles are the lowest. And the B & A saddles are in between the E-E and G-D saddles. They should form an arch like the radius on the fingerboard if you get my drift.
Old 01-26-2007, 09:26 AM
bcgvh  is offline
you guys might be right about the b and e saddles being switched, I will have to check it out later today and see if I can switch them.
Old 01-27-2007, 02:08 AM
Ironjose  is offline
Posts: 1,060  -  iTrader: (0)
yep... that happends when you take your guitar to inexperience "techs" jaja i bought a guitar like that and i didnt know what to do... until i took the tremolo off the guitar and take it apart, piece by piece
JJ
Old 10-17-2008, 02:21 PM
tza  is offline
Posts: 8  -  iTrader: (0)
im having a similar problem with the Bridge on my ibanez, it's not an OFR, but a licensed version, i think maybe a lo-Pro Edge
the G string on the guitar is sitting higher than all the other strings by a fair enough amount that you can see it clearly and it's making it difficult to play
"On the Gibson and Floyd Rose style bridges the base plates holding the individual string saddles are generally designed to allow for the radius of the fret board so adjusting individual string height is only possible by placing a shim underneath the individual saddles on the Floyd style and not possible without replacing the blade on the Gibson style which would be a rare thing to do in either case"
this is from a site, says it's not possible to lower individual strings without using a shim or something
can anybody help me lower it by this or another method .... or am i beat and should just get a whole new bridge ??????
thanks
Old 10-17-2008, 02:25 PM
Rich  is offline
Check to see if the lockdown screw washer is under the saddle.
Old 10-17-2008, 02:49 PM
tza  is offline
yes, i believe it is
Old 10-17-2008, 02:51 PM
Rich  is offline
Put it back where it belongs
Old 10-17-2008, 02:54 PM
tza  is offline
( i know very little of this, and the guitar store here couldn't help at all )
i've taken off the string, lockdown screw , and saddle.....
it was where it was supposed to be
*edit*
i put everything back together, and it seems fine now, i don't know what happened but THANK YOU
for saving my guitar from the last 6-8 months of hell
floyd rose
floyd rose moves when bending a string bujecas Tech: Setup, Repairs and Mods 17 09-01-2008 07:46 AM
Floyd Rose parts in the UK dex Tech: Setup, Repairs and Mods 1 12-11-2006 07:12 AM
Floyd rose going out of tune when I snap a string Anton Other Ibanez Guitars (including Premiums) 8 06-25-2003 08:37 PM
Floyd Rose Question MichaelQ Tech: Setup, Repairs and Mods 5 12-30-2002 02:32 PM
New Floyd Rose? ripl3y Gear and Equipment 45 09-16-2002 03:36 PM
