Old 01-15-2009, 04:55 AM
IanRG7421XL  is offline
Posts: 385  -  iTrader: (1)
Original Floyd Rose help please!
I recently replaced the licensed floyd rose on my esp ltd mh-300 with an Original Floyd Rose. The only issue I am having is adjusting the string height. The bridge is sitting at the appropriate height yet the strings are sitting a bit to low and causing some buzzing. I would like the action to be higher but how can I do this without raising the trem any higher? thanks for the help in advance.
Old 01-15-2009, 03:44 PM
Foulacy  is offline
Posts: 354  -  iTrader: (0)
Re: Original Floyd Rose help please!
you find the magical string height raising fairy and ask her to do it.
... or you raise the bridge. you can also take the neck off and see if there's a shim, and if there is, remove it.
Old 01-15-2009, 04:04 PM
it's a set neck. and i said the bridge is already at an appropriate height. I don't want to raise it any higher. It is where it is supposed to be.
Old 01-15-2009, 05:04 PM
LonePhantom  is offline
Posts: 5,368  -  iTrader: (6)
Reviews: 98
You probably need to shim the saddles if the radius of the neck is different to the trem.
But really if they are all sitting low and buzzing you need to raise the trem.
The trem is obviously not at the appropriate height for your guitar if the strings are buzzing. There is no real set height for the trem anyway, just what ever gets you the best action without string buzz.
Old 01-16-2009, 12:13 AM
Ayrton  is offline
Google "Floyd Rose shims".
Buy from the vendor of your choice.
floyd rose, ofr
floyd rose original vs pro newbieguitarmaker Gear and Equipment 16 11-17-2010 09:32 PM
JS with Original Floyd rose kirklec88 JS (Satriani Model) Ibanez Guitars 11 09-26-2006 08:03 PM
Original Floyd Rose skrewflanders Tech: Setup, Repairs and Mods 1 12-23-2005 05:00 AM
Original Floyd Rose clar-v-d JS (Satriani Model) Ibanez Guitars 2 10-27-2004 05:45 PM
Floyd Rose Cavity: Lo Pro Edge same as Original Floyd rose - Captain Ron Tech: Setup, Repairs and Mods 2 09-06-2001 01:06 AM
