Tech: Setup, Repairs and Mods
Output jack flaked out
07-15-2006, 08:03 PM
moro
Posts: 623 - iTrader: (
Something odd just happened with the output jack on my Jem. I wasn't getting any sound and I noticed that the plug wasn't inserted all the way. When I went to push it in, I was getting some resistance. So I kind of forced it in there and now I only get sound if the jack is pulled out about a quarter of an inch.
Is this a common problem? Is there an easy fix or should I just replace the output jack?
Thanks.
moro
Find all posts by moro
07-15-2006, 08:09 PM
ryanb
Posts: 1,457 - iTrader: (
Re: Output jack flaked out
Sounds like it's time for a new jack. The contact is bent or broken off.
ryanb
Find all posts by ryanb
07-15-2006, 09:18 PM
sniperfrommars1
Posts: 3,302 - iTrader: (
Take the backplate off that covers your output jack. Make sure the contact isnt broken off, if it is broken replace, if it is bent, just bend the thing back in place, but you may wish to have it replaced. Unsolder the output jack and take it to your local
ibanez dealer
, as its a particular type of flushmount jack and wont be in stock in just any
guitar shop
sniperfrommars1
Find all posts by sniperfrommars1
07-15-2006, 09:36 PM
moro
Unfortunately, the jack is closed off on the end, so there's no way easy way to get in there and bend anything back.
I'll try replacing it myself. Thanks for the help, guys.
moro
07-15-2006, 09:51 PM
sniperfrommars1
If its not broken then you could still bend it backin place with a precision screwdriver most likely, not sure never tried it on this type of jack.
sniperfrommars1
07-16-2006, 12:07 AM
moro
I tried. It's way too tight in there to do even with a precision screwdriver. You'd need a very small L-shaped tool or something to pry the contact up.
moro
07-16-2006, 06:03 AM
sniperfrommars1
moro
Those little picks they use for scraping earwax etc. would work. They have a little L shaped end for grabbing things in the ear canal. I assuem you could get one at a drug store for a few bucks. Would be worth it if you could do that rather than have to replace the thing :P
sniperfrommars1
07-16-2006, 11:56 AM
moro
Lol. I'll check out the drug store today.
moro
guitar shop
ibanez dealer
ibanez v7 output?
HOW TO MEASURE PICKUP OUTPUT
g system mono output left or right?
how to wire active jack
epiphone guitar output jack mono or stereo?
help wiring an output jack on my 77dbk
prefontainenike
Pickups & wiring
06:33 PM
measurement for output jack cover
chef21
03:54 PM
Stereo output jack?
Petie
Pickups & wiring
03:26 PM
Output Jack
eg
Pickups & wiring
09:54 PM
A new output jack - Will any jack do?
SalemB
04:39 PM
06:26 AM
