Old 06-15-2009, 06:13 AM
Homebake  is offline
Posts: 1,041  -  iTrader: (1)
overnight neck tension
i've run out of strings (bought a pack of 4 off the bay like 20 days ago, not here yet...) and my high E just snapped so i've taken all the strings off and done a major setup and clean of my rg2550z. getting a new pack of strings tomorrow.
i can see the neck has visibly bent upwards without the tension of the strings on it, should i loosen it a bit overnight? i use .10s.
Old 06-15-2009, 06:32 AM
Jacob K  is offline
Posts: 183  -  iTrader: (0)
Re: overnight neck tension
I wouldn't do it - my logic says that if the neck was fine while it had strings on it, it will move back to the same position when the tension is re-applied (or at least very close to it).
Old 06-15-2009, 06:39 AM
Homebake  is offline
mmm, but i don't wanna wake up tomorrow morning and find out i've damaged it somehow.
i'm sure it will be fine.
Old 06-15-2009, 09:02 PM
LonePhantom  is offline
Posts: 5,368  -  iTrader: (6)
Reviews: 98
It's not going to get damaged just because it's missing a string overnight. People have had guitars in closets with no strings for years and the neck has been fine.
I had a neck I bought for a project sit around for months, and it's been on finished product for a few years now absolutely fine.
Old 06-15-2009, 10:40 PM
jemaholic  is offline
Posts: 2,806  -  iTrader: (14)
Images: 13
If you keep using the same gauge strings it should be fine. If it was strung with 10's and you restrung it with 9's the lesser tension of the 9's might cause the neck to bow a bit.
Easily fixed with a truss rod adjuster.
~j
Old 06-16-2009, 02:15 AM
Homebake  is offline
i took off all the strings.
and yeah, i restrung it just then and it's fine
neck, string tension, warp
weird - guitars going sharp overnight. LowYaw Tech: Setup, Repairs and Mods 12 05-13-2009 09:56 AM
neck tension and string change NaHuELoidE Tech: Setup, Repairs and Mods 3 08-19-2006 10:31 PM
USRG Series Tension Free™ Neck karmatronic J-Custom, USA Custom & Prestige Ibanez Guitars 3 08-25-2005 10:41 AM
Ibanez tension free neck , what is it? Ibanez Junkie Other Ibanez Guitars (including Premiums) 1 04-22-2004 12:15 PM
Neck tension on my Jem Scott 74 JEM and Universe Guitars 6 06-14-2001 06:42 AM
