Re: Painting question?!
Ok now a clear coat question. I am using the Krylon Fusion clear that is recommended many times here. I put on two dusting coats, then a little thicker but still pretty dry. Let it sit 24 hours, sanded with 800 grit very lightly. Then a couple more coats, this time a little thicker, let it dry 24 hours +, Was going to put on some more today, but the last coats look a little cloudy what should I do from here? Did I do something wrong? Im in Florida so humidity is high, but there is no avoiding it here.
