Old 02-29-2008, 02:51 PM
peter762033  is offline
Posts: 91  -  iTrader: (1)
parts build
Hi, just wondering how easy this it to do, ive never done this before, is it hard to get it all setup correctly and playing nicely by myself? Does it work out cheaper than buying a whole guitar ready assembled? Any info appreciated,
thanks
Old 02-29-2008, 03:15 PM
jaxadam  is offline
Classified Watchdog
Posts: 3,042  -  iTrader: (9)
Re: parts build
Depends.
If you're getting, say, an Ibanez neck, an Ibanez body, Ibanez parts, etc..., it can work fine.
You can run into difficulties with frankenstein's and other various different manufacturers parts.
Old 02-29-2008, 03:27 PM
Re: parts build
Ok i was thinknig all ibanez. Ive looked at a few parts to buy and the trems seem to be pretty expensive on their own, anyone got a good parts site?
thanks
Old 02-29-2008, 03:30 PM
jaxadam  is offline
Classified Watchdog
Re: parts build
You shouldn't have a problem and yes, some parts will be expensive.
Old 02-29-2008, 03:45 PM
Jaden  is offline
Posts: 2,464  -  iTrader: (7)
Re: parts build
no, buying a guitar off the shelf is cheaper...
and depending on what you buy you can have problems....
give it a go - if all else fails give it to a tech who can set it up for you once youve put it together !
Old 02-29-2008, 06:40 PM
ryanb  is offline
Posts: 1,457  -  iTrader: (0)
Re: parts build
Right. Building from parts will cost you more every time. Don't do it to save money. Do it for the experience, or to end up with something custom that you can't get elsewhere.
Old 02-29-2008, 07:42 PM
losgatosrg350dx  is offline
Posts: 848  -  iTrader: (0)
Re: parts build
i always save money building my guitars
<img src=http://i26.photobucket.com/albums/c143/confederatewk/downneck.jpg>
warmoth throughout
jackson pro style neck with angled headstock reverse headstock, 16 inch flat radius neck stainless steel frets, ebony fretboard on maple neck, corian nut
alder v2 body h x h contoured heel
volume coil tapping, selector, tone
hardware is
locking tuners
dimarzio x2n bridge
duncan distortion neck
1 meg push pull coil tap volume
selector wired normal - double pole center venter selection makes parallel wiring on both pickups, each other way is normal
500k tone with .022 cap
all shielded wiring and cavaties
and a kahler fixed bridge 3300 fine tuner with stainless steel saddles - 3310
all this was about 1200 in parts
add a bottle of tunoil MINWAX
and some solder and black paint on the headstock
let me tell u something, blows away just about any ibanez, but word on the ibanezez...and still building ur guitar right off the shelf with ordered parts, is the way to go, then you dont need to rely on a model built of customization that can limit you....etc....
shred it foo
Old 03-01-2008, 11:47 AM
RG462  is offline
Posts: 507  -  iTrader: (0)
Re: parts build
I am currently building an Ibanez guitar using custom jem parts. If you price hunt, you will get it for cheaper. If you buy new ibanez parts, you will not benefit other than the experience of building.
Old 03-01-2008, 11:52 AM
screamndemon69  is offline
Posts: 5,676  -  iTrader: (12)
Re: parts build
Usually buying a used WHOLE guitar with parts and modifying the heck out of it is far cheaper than buying things piece by piece.
Find a used RG that is as close as you can get to what you want and modify and re-finish to suit you.
Let us know how it goes for you when you get closer to finishing the project.
Old 03-01-2008, 12:16 PM
RG462  is offline
Re: parts build
yeah, screamn brings up a good point. If you want a guitar that is nothing like a stock model, thats when you need to order custom parts piece by piece
Old 03-02-2008, 03:16 PM
Re: parts build
Ok thanks guys, il think it over
coil tap, coil tapping, custom jem, duncan distortion, ebony fretboard, fixed bridge, ibanez neck, locking tuners, maple neck, pull coil, pull coil tap, reverse headstock, stainless steel frets, steel frets
FS - parts guitars parts old_metal_head Classified Ads: Guitars and Gear 7 05-23-2007 08:56 PM
FS: Grover Tuners and Taylor Acoustic Parts ZOMB13 Classified Ads: Guitars and Gear 2 04-25-2007 12:01 AM
FS: Ibanez RG Parts, Etc. 3rdfretmusic Classified Ads: Guitars and Gear 10 12-21-2006 11:55 PM
Need suggestions for parts for my UV7BK'97 nmanel Tech: Setup, Repairs and Mods 4 01-25-2006 11:15 PM
Ibanez Parts Prices Go INSANE!!!! TAorama Vendors, Auction & Reseller Talk 21 09-14-2005 10:33 AM
