Old 03-25-2009, 10:12 AM
jrpalomo  is offline
Posts: 57  -  iTrader: (0)
Pedal hum problem
Guys can you help me? I have an Original MXR carbon copy delay. Now when i turn it on theres a hum comming out. when its off, theres no hum. I tried using both batteries and Voodoo Labs power supply and it still has hum. I also used 2 amps....still hum. I also switched my cables with it and theres still hum. It cant be the guitar cause even if theres nothing plugged to the end still hum or if im using the humbucker on the guitar still hum, even if the volume is on zero on the guitar theres still hum. Can you guys help me?
Old 03-25-2009, 12:21 PM
morikh  is offline
Posts: 31  -  iTrader: (0)
Re: Pedal hum problem
hm
sounds that problem maybe is in the effect jacks
Old 03-25-2009, 02:24 PM
callen3615  is offline
Posts: 1,412  -  iTrader: (7)
Double post problem.
Seriously. Send it back for repair.
hum, pedal, problem
pedal pad MKS mps-xl NP with pedal patch and pedal power just42dave Classified Ads: Guitars and Gear 0 02-27-2009 10:33 PM
Problem with Boss DD-3 (delay pedal) and 9 Volt adapter superhairycamel Gear and Equipment 1 03-21-2008 03:03 AM
Need help with pedal problem... DKCustom Gear and Equipment 3 04-11-2007 08:31 PM
Pedal board power problem. Rotti Gear and Equipment 7 02-05-2007 11:31 PM
Little Alligator Volume Pedal Problem... - issue or not? Gabe Nickelson Gear and Equipment 4 07-20-2001 01:28 AM
