Pick Up Repair - Screw holes are too big
I have 2 pickups that were modified for direct mount. The adjustment screw holes were drilled out and I need to know of a way to fill these so I may re-drill the hole to accomodate a pick guard mount. I was thinking solder or epoxy, but any suggestions will do.
NOTE: The body is not designed for direct mount pick ups and it would be easier to repair the pups than mod the body..
Thanks
J>
