Old 02-16-2006, 02:18 PM
waylay00  is offline
Posts: 3,763  -  iTrader: (10)
Pickup Covers/Caps
How hard are pickup caps to install on a humbucker? I don't see how one would install then on a humbucker.
But sites such as Jeannie's Pickguards and Pickguard Paradise offer pickup covers for humbuckers.
How do you install them?
Thanks
Old 02-16-2006, 08:21 PM
Ant1981  is offline
Posts: 2,181  -  iTrader: (3)
Re: Pickup Covers/Caps
How do you mean pickup covers? Do you mean the plastic that the pole pieces are in that you can see from the outside?
If it is that, i've always been told that humbuckers are wax potted and you cant replace those parts, but on single coils you can. Hope this helps a bit.
Old 02-16-2006, 08:38 PM
ryanb  is offline
Posts: 1,457  -  iTrader: (0)
If you mean the so-called bobbin-toppers, they are basically just colored stickers that you stick to the top of the pickup. Humbuckers don't have replaceable covers like single coils. (That is, except for the metal can style covers, ala Gibson, etc. that are soldered over the whole humbucker.
Old 02-16-2006, 10:03 PM
waylay00  is offline
Yeah, I guess I was wondering about the bobbins. So do you just stick these on? Glue? Are they easily removed?
Old 02-17-2006, 12:30 AM
guitardevil2005  is offline
Posts: 442  -  iTrader: (0)
i dont know but im guessing its like a sticker
Old 02-17-2006, 06:26 AM
Liggy  is offline
Posts: 221  -  iTrader: (4)
Yeah, its a peel off sticker with holes precut for the pole pieces.
Make sure you order 'F' spaced or normal depending on what pickups you have, otherwise the holes are slightly out
They can be easily removed as well!!
pickguard paradise, pickup cover
RG7 Pickup config desertdweller Other 7-string Guitars 4 10-18-2004 09:29 PM
Breed bridge PU: describing the mids Ced777 Pickups & wiring 13 04-19-2004 05:49 PM
Pickup adjustment problem. RG-Head Tech: Setup, Repairs and Mods 2 01-29-2004 05:47 PM
Parker Fly owners, pickup info. bammbamm Pickups & wiring 6 02-11-2003 10:35 AM
Pickup Issue.. - Problem with wiring? MrBungle Pickups & wiring 5 04-15-2002 10:03 PM
