These are in a pickguard, right? (never owned a UV myself)
If they are, the spring inbetween the pickup and pickguard probably won't compress any farther.. The way to fix this, is to either replace the spring with a shorter one, or (like me) cut the current spring down a bit.. This should let you raise the pickup up..
Hope this helps...
