Old 05-20-2006, 03:19 AM
rainonthegrave  is offline
Posts: 14  -  iTrader: (0)
Please Guys Help Me With My Tremolo Plzzzzz
Hello Guys
I Have An Ibanez s470q with An Ibanez lo-trs Trem II
And My Prob Is
When I Pull The Bridge Back Or forward ( With The Wammy Bar )
The Bridge is Not Back To The right Position
And The Guitar Will be not In Tune
I Mean
When I Pull It Back The Tune Will Be High
And When I Pull It Forward The Tune will Be Low
I changed the sprigs 4 time and nothin happend
What Should I Do Please Help Me
And Another Question
Can i replace This Bridge With Edge Pro II tremolo????
And If Not What Shoud I Buy??
Plz Guys Help Me
Thanx A Lot
With All Respects
Old 05-20-2006, 09:56 AM
TheJazzTerminator  is offline
Posts: 544  -  iTrader: (1)
Re: Please Guys Help Me With My Tremolo Plzzzzz
How old are the strings? Did you stretch the living **** out of them?
Old 05-20-2006, 10:23 AM
The Extremist  is offline
Posts: 110  -  iTrader: (0)
http://www.ibanezrules.com/tech/setu..._stability.htm
Old 05-20-2006, 05:47 PM
john1880  is offline
Posts: 468  -  iTrader: (1)
hey rainonthegrave. here is my take on what could be wrong.
1) if your tremolo is ****-eyed, it'll bind and cause it to not return properly. i just had this happen. i turned one stud like 1/4 turn and it took care of it. it had a nice bounce and everything. tap on the trem itself and you should feel a slight "bounce". thats how you'll know that both studs are level.
2) your studs are worn or knife edges worn.
3)also check your locking nut and be sure those two screws are snug. they will loosen up over time. as a matter of fact, i would check the neck bolts and even the saddle adjustment screws. they all loosen up with time.
tremolo: i would replace it with an Original Floyd Rose. Or an edge if you want to remove some wood.
keep us posted
Old 05-21-2006, 03:48 AM
Ironjose  is online
Posts: 1,061  -  iTrader: (0)
hey man i have the same problem with GIO but right now what i did was that i fixed the tremolo to be like a hardtail one, put some pieces of wood in the middle of the trem block and the walls of the trem cavity so the trem cant move, but the right and accurate solution is the change the trems coz it simply sucks. i´m changing it with an original floyd rose but i want to know if the original floyd rose pro fits, if it does i´d probably go for that one.
JJ
Old 05-21-2006, 08:50 AM
Thanx A Lot Guys
But I Wanna Ask U Ironjose
Can U Explain where is the blocks??? do u mean the saddles and do u have the same guitar???
if u have the same did u change ur trem tothe original floyed rose?? and dose it fit???
anyway this is my guitar pic on this link:
http://www.aplusguitars.com/ibanez_s470qs_trans_red.htm
guys any one know if the floyd rose pro or the original fit without removing some wood ?? plz help me with this
thanx a lot guys
Old 05-22-2006, 06:40 PM
Racerx2k  is offline
Posts: 1,076  -  iTrader: (0)
Fairly common prob, with the Lo-TRS II trem. Had it myself, which is why I got rid of it, as soon as I got it. YOu can try chapstick on the trem's contact points with the posts, and other lube ideas, but, in the end, it may just be that your trem, or posts are worn.
floyd rose, floyd rose pro, locking nut, neck bolts, trem block
safe to leave tremolo bar in edge while in case? sindlei Tech: Setup, Repairs and Mods 6 02-01-2005 07:35 PM
need help with a problem with my tremolo! Omso J-Custom, USA Custom & Prestige Ibanez Guitars 9 09-12-2004 02:07 PM
Leaned RG tremolo post voyager Tech: Setup, Repairs and Mods 3 12-26-2003 06:20 AM
Unbalanced tremolo zEr0 Tech: Setup, Repairs and Mods 4 10-09-2003 03:34 PM
