Old 04-11-2001, 03:36 PM
tomizm  is offline
Posts: 417  -  iTrader: (1)
Power supplies, preamps and power amps - whats the more idea
When building a rack of stuff, how should you arrange the items? *Power supply further from the preamp or power amp, where does more noise come from?
Maybe post should be moved to GEAR column instead?
(Edited by tomizm at 4:02 pm on April 11, 2001)
Old 04-11-2001, 07:15 PM
dwswift  is offline
Posts: 165  -  iTrader: (0)
Sound wise, it really won't make a difference. *You have to worry about ventilation though. *Usually... the power supply goes on the top, then fx units, preamps, and power amps in the bottom (some people have seperate racks just for power amps.) *It is sometimes recommended that you leave an open space above or below some of the peices that cause lots of heat. *Also consider weight of each unit, heaviest towards the bottom.
Old 04-11-2001, 07:56 PM
tomizm  is offline
Some units aren't more succeptible to noise than others? *I'd be afraid to put an AC unit right next to preamp for fear the preamp would amplify miscellaneous noise from the AC adaptor.
power amp, power amps
