Originally Posted by theapprentice
Hello everyone, I just got my very first tube amp, a Laney LC50-II, which has 4 12AX7s and 2 EL34Bs. I was browsing through the manual while checking out some jemsite threads, when I found a page in the amp manual about the tube sockets being labelled V1 through V4 for the preamp tubes and V5 and V6 for the power section. Now, I found some threads here talking about how 'this' 12AX7 is good for V1 while 'that' 12AX7 is better for V2 and so on.
What exactly do these positions do for a tube amp? I admit that I am a complete beginner when it comes to more technical aspects of the tube amplifier, so please enlighten me.
first the similar manual is here
at laney site lc50-112
download manual
you could see it easly that your amp is similer to this amps manual.go to page 13(block diagram)
and walla....
half of v1 is v1b:is common part for both drive and clean chanel
half of v1 for(v1a) and v3 tubes for drive chanel
v2 is for clean chanel only...
v4is phase invertor section for power amp
now if you like puncy distortions and chimmy cleans---i have an advise for you about tubes
for v1--use ultra low micraponics and noiseless tube this means low noise and micraphonics selected and tested jj ecc83-this tube gives you hi gain apart and musical defination on both cleans and drive but expecially drive channel...
for v2--use much more musical tubes for this chanel it doesn't matter hi gain or not..but my advise is tungsol ecc83 or jjecc 803 tubes.both of them are dynamic but ecc 803 is little bassy
forv3--use hi gain selected tungsol ecc83-thats the way to get an hi gain drive cascade..or you may pick eh 12ax7 lps for less his.but you absolutly lose the mids and defination.all the time i chose tungsol for drive channels.low noise hi gain and much musical balanced tones
for v4-this is an importand point..v4 is a signal diveder and drives the power tubes.this tube must be mached triod.because mached triod tube could drive power tubes at the same ratio..this will increase the power tube life-much musical sound and better defination.
and you may use 12 at7 or ecc82 for this state if you can not find mached triode 12ax7 or ecc83.you get lower volume from amp but you will be in the security and quality area..
stay cool and experiment with your own..welcome to the tube jungle
cihan
