Old 11-17-2009, 06:00 AM
kev_nz  is offline
Posts: 2  -  iTrader: (0)
Preventing loose strap buttons
Hey guys,
I've just bought my first solid-body electric.
I understand that loose strap buttons (i.e., worn/stripped threads) are a very common and troublesome occurance that can happen over time with the entire weight of the guitar resting on the strap buttons.
Is there anything easy I can do while the guitar is still brand new to stop this from happening in the future?
E.g., drip some wood glue into the strap button hole to strengthen the wooden threads?
Or apply some loctite to the wood screws?
Any ideas would be much appreciated!
Cheers,
Kev
Old 11-17-2009, 11:10 AM
SonicProvocateur  is online
Posts: 1,104  -  iTrader: (0)
Images: 3
Reviews: 39
Re: Preventing loose strap buttons
You've got the right idea. What I did as a guitar tech if someone had a stripped thread was to take some super glue (sounds silly, but totally works, and will last!) and sawdust and refill the thread hole. Once it is set, you can re-install the strap button and it will be good as new!
The sawdust is very important; all that guitar weight will tear through superglue, but using sawdust will "remake" the wood there and help grab onto the threads.
Hope this helps!
Old 11-17-2009, 02:30 PM
MJ Slaughter  is offline
Posts: 28  -  iTrader: (0)
A good quick fix I've used a couple of times when my strap buttons become loose is to put a piece of toothpick or wooden matchstick in the hole then screw in the button. It doesn't take much. Using the soft wood toothpick or matchstick was always enough to give the screw a good hold and I never had a problem after that.
Old 11-20-2009, 02:08 PM
j.t..i.  is offline
Posts: 129  -  iTrader: (0)
was gonna say this. a toothpick
Old 11-20-2009, 10:37 PM
spudler_t  is offline
Posts: 75  -  iTrader: (0)
Reviews: 12
I just bought a body where the strap button was pulled out. I took a couple toothpicks cut them to little slivers the depth of the hole. I took some wood glue dipped each sliver in the glue then stuffed them in the hole added a little more glue to the hole. I then threaded the button and screw in the hole till it was about 1/16-1/8 from tight, waited till the next day, removed the screw and button. I then cleaned up any glue or tooth picks that stuck out. I reinstalled button and screw, Tightened it and it worked great.
Old 11-20-2009, 11:15 PM
DEADTUNES666  is offline
Posts: 2,174  -  iTrader: (1)
Reviews: 12
Red face
Use c0cktail toothpicks because they are bigger than normal ones...
strap button
What's this stuff on the strap buttons? Myst and rain Gear and Equipment 20 11-26-2008 05:43 PM
jem strap buttons Devon8822 JEM and Universe Guitars 2 11-20-2008 04:43 AM
Do something about the strap buttons... mfergel Comments to Ibanez 2 10-28-2006 11:03 AM
RGT3120 Strap Buttons Type O- J-Custom, USA Custom & Prestige Ibanez Guitars 8 10-19-2002 10:58 AM
How can I get strap buttons tight on a RG? Lauri M Tech: Setup, Repairs and Mods 9 05-25-2002 10:13 PM
