Hey i just took it apart. I have to say i'm really amazed at the simple circuitry. Whilst i have singled out the problem, i am still perplexed at how it could've developed.
The circuit is really simple. You have 3 leds, 1 acting as a dummy load, and the other 2 facing an LDR each (Light Dependent Resistor). As the amount of light hitting the LDRs increases, so does the volume.
Now, my problem occurs whenever i set the minimum volume level anywhere above zero. This is where the 2nd LED comes into play, and where the problem is. The plate which moves in front of both resistors has 2 slots, one for each LED. As I move the pedal down to the lowest point, the light hitting the 2nd LDR decreases, but then increases again. This is what caused that volume increase which was my problem.
What i have left to do is figure out some way to stop this over-travel of the pedal, maybe i'll just stick something to the bottom of the pedal so it stops sooner.
Anyways, tnx alot bamm
