Tech: Setup, Repairs and Mods
Problem with my Lo Pro Edge Tremolo!!! Won´t keep pitch!!
06-11-2004, 12:18 PM
quiel
Posts: 13 - iTrader: (
Hi. I live in Argentina and bought from ebay´s two years ago a jem 7v which comes with a lo
pro edge
. I´ve changed a couple of times the strings, made some some adjustments though I´m not very used to.
The thing is that when I use the tremolo I loose the picth. I don´t know if I have to change the three springs or what!! I´m worried about this, thinking my
floyd rose
might be defective.
If anybody knows what to do, please tell me.
quiel
Find all posts by quiel
06-11-2004, 12:49 PM
Posts: 19,352 - iTrader: (
Could be just procedure or user error, could be something worse. Here's the place to start
http://www.ibanezrules.com/tech/setu..._stability.htm
06-11-2004, 11:52 PM
Kontalonis
Posts: 1,006 - iTrader: (
Take it to your local
guitar tech
and have him set intonation and
bridge angle
. Should be golden then.
Kontalonis
Find all posts by Kontalonis
06-13-2004, 12:12 AM
MicJustMic
Posts: 931 - iTrader: (
Changed a couple of times the strings? I hope in two years you've changed them more than a couple, unless you only play the guitar a few times a month. :-)
Did you stretch the strings? This is often the most commen "problem" with FR trems if you're not familiar with them.
You MUST stretch the strings, go to Rich's site for detailed instructions.
If that's not the case, simply follow Rich's instructions for checking everything out.
Mic
MicJustMic
Visit MicJustMic's homepage!
Find all posts by MicJustMic
06-14-2004, 09:56 AM
quiel
Thanks everybody for your concerne. I want to learn how to maintain my guitar. I followed Rick´s instructions, but still have the problem. Maybe one of the knives edges could cause the problem. The straight knife edge is not perfectly straight, it has a very little imperfection due to post contact. I've compared this middle part of the knife I'm talking with the rest of the knife, and it has the same thickness. This tells me that the thickness is almost the same as when it was bought new (by the guy sold).
If the problem lies in the knifes, could I replace them? Or do I have to spend my all the little money I have on a new floyd rose??
thanks to everybody...
Ezequiel
quiel
06-14-2004, 10:13 AM
quiel
Sorry, I forgot to tell you that it is not a problem of strings. I change them regularly. Also, I can see by eye, that the when I pull one way, and then to the opposite, it doesn´t return to the position. If I can see this, imagine the sound!!
Ezequiel
quiel
06-14-2004, 12:07 PM
MicJustMic
Again I ask, did you stretch the strings?
If the strings are not stretched you will see (and hear) drastic changes in the angle when you not only use the trem, but even bending strings.
You said you changed the strings, okay, that's good, new strings is always good, but if they are not stretched they will stay in tune WORSE than old strings.
Mic
MicJustMic
06-14-2004, 12:24 PM
quiel
Yes Mic. I did. Eventhough with the old strings (aprox. 6 months of use: they were very stretched) I had the same problem.
Thanks
Ezequiel
quiel
06-14-2004, 12:30 PM
quiel
I think I always have the problem since I bought it from ebay two years ago. I thought that it was natural for the tremolo to loose pitch (thanks to my ignorance). A few months ago talking with a friend, I understood I was having a big problem. Should I use more than three springs?? Change them??
Ezequiel
quiel
06-14-2004, 01:03 PM
Sounds like either pickguard interference, fat knives/pinched studs, or loose inserts. You're not explaining anything about how it's going out of tune when it is to determine, but, your answer IS here
06-14-2004, 01:29 PM
quiel
Hi Rich. I already followed all the steps mentioned on the link. I removed the tremolo, cleaned the posts and knives. The knife edge which is NOT round, could be a little bit thick. As it is straight, in the middle is were it is in touch with the post; the rest of the knife, I suppose should be the same as when first bought the guitar (do you follow me?). I compared the middle of the knife with the rest and it there is the same thickness, and a slight difference in texture(the post-trace).
If I move tremolo from one way (pull), watch measure the position of the tremolo, then move again the tremolo to the opposite side, the tremolo returns to a different position. Of course, the pitch is very different.
quiel
06-14-2004, 01:35 PM
Move the bar down only and if you started in pitch it always returns in pitch correct? And the noses on the trem are not making contact with the pickguard right? Fat knives/pinched studs.
06-14-2004, 01:51 PM
quiel
1) I move the bar down
2) Let it come again
3) Meassure pitch
4) Move the bar down again
5) Release the bar
6) Measure the pitch
Result: Good, no big change in pitch
But if:
2) Release
3) Meassure
4) Move the bar up
5) Release
Result: Huge change in pitch, I even can see by eye that there are different positions for the tremolo!!!
Talking about the contacts, the only contact between the guitar and posts are the knives and posts. Nothing else is in touch.
quiel
06-14-2004, 02:03 PM
Always sharp? Fat knives/pinched studs.
06-14-2004, 03:22 PM
MicJustMic
Just curious, how HUGE a change in pitch?
Rich said fat knives/pinched studs and I think everyone else will agree . . .
This can cause as much as a half step sharp on your low E string in the worst case. (This is rare, however)
Just remember though, "100% Perfect Float" is more rare than platinum. Most guitars will still be a touch sharp on pull-up even with nearly perfect knives and studs.
Rich has found that a little Chap-stick on the studs helps with this (though my G string still comes back 4 cents sharp, I can live with that, I just split the differance when I tune, 2 cent flat from dropped and all sounds fine to the ear ;-) ).
Pain in the tucas, isn't it?
Once these things are working as well as they can, they are hard to give up once you get used to "perfect" tuning. :-)
Mic
PS
Are the studs locked properly? Sometimes this can fix 50% to 90% of common tuning problems with the Edge.
MicJustMic
bridge angle
floyd rose
guitar tech
pro edge
how to measure tremolo to scale
what metal is edge 3 tremolo made out of
how to setup an edge 3 tremolo
is the edge zero tremolo a good tremolo
09:22 AM
