Problems w/G-string on UV777PBK
I'm having an issue with my G string, namely that when I'm Vai-like on the trem, the G string will go horribly flat (5 cents or so). If I just keep using the fine-tuners to get it back in tune, eventually I've got the G-string fine-tuner bottomed out, and the rest in their usual positions.
The weird thing is, you'd think the saddle was slipping, but it's not, as intonation is fine once I've retuned. Anyone have any ideas? The problem persists after strings changes, so it's not the strings.
