Old 12-02-2008, 04:04 PM
Von Styne  is offline
Posts: 42  -  iTrader: (0)
project: S 540 sol: neck & refinish
Hey guys, I had some threads on advice on my guitar project.Its a 1992 S540 ltd sol H & S era. I cracked my neck and decided that when I replace it I'll do a over haul. So I got some input,got my new neck and supplies.
I have begun the project. At this point I have taken everything off of the body and the new neck has the hardware from the old neck.I used some mineral spirits ( very lightly) and some 0000 steel wool to thin out the tung oil before sanding.( I was told to do this,but was skeptical.It did get all that dirt out though)Then I was able to get some sanding in last night, but not much. I'm starting with 800 grit.
I also have a question about what appears to be sinking wood around the middle pickup on the right side of the picture Ibanez 15a. You can see that the wood is a bit darker and well rounded compared to the left. I was thinking that I can steam it out with a soldiering iron? I read something along those lines in the Guitar Repair book by Dan Earlwine. Any thoughts?
I'll update this thread as I progress.
So any help and advice is welcomed. Thanks, Von
Old 12-02-2008, 08:55 PM
hotwax1989  is offline
Posts: 71  -  iTrader: (0)
Re: project: S 540 sol: neck & refinish
I'm no expert on your application, but i think you should start sanding with a much coarser grit than 800.
On an rg body, i started with 60, then workd my way up to 100, 120, 160 (not necessary, but it was handy) then 320 before painting, and inbetween coats. Its very smooth. I followed some of the tips from project guitar. As for the tung oil, i have no idea. Good luck!
Old 12-02-2008, 09:39 PM
waylay00  is offline
Posts: 3,763  -  iTrader: (10)
Aww, don't refinish that guitar!
Old 12-03-2008, 01:31 PM
for the sanding, I just wanted to do some surface sanding to get some small scratches and dirt build up out. I am going to reapply tung oil after,so It'll look like it did when it was new.
Waylay,what makes you say that? is it because its not as bad as I think it is? just curious..
Old 12-11-2008, 12:43 PM
ok, I have a question about shield painting. Should I shield paint before or after applying the tung oil. I have all the sanding done and I'm about to get some shield paint. So what is the perferred method at this point?
Old 12-15-2008, 03:54 PM
so here is a few pics of where I'm at with the guitar. This is after I put on a 2nd coat of tung oil and buffed it out a bit.
I've noticed there are a few "fingerprints" like smugges on the top behind the bridge. It looks like those areas didn't get enough oil. I'm kinda on pause until I can find more out about removing those spots. Anyone have ideas?
Old 01-05-2009, 03:59 PM
Hi everyone, I have finished my guitar. I'm more than happy with the results and and I wanted to thank everyone who commented and helped me out on the way. Thanks to Rich for all the parts. Here is a few pics of it finished and if you want to look at more here is a link to the photo album on my myspace. http://viewmorepics.myspace.com/inde...lbumId=2139563
Old 01-05-2009, 04:28 PM
Ryan350DX  is offline
Posts: 179  -  iTrader: (0)
I love seeing you guys tearing the paint off and showing the natural grain. Im buying an S320 and doing the same. Im looking for pointers.
Old 01-05-2009, 05:53 PM
I never had to tear off any paint being it was an tung oil finish from the factory, but thanks for the comment. I like looking at those projects, its inspiring.
well, IDK about the paint removal, but I used sandpaper grits 320,400,600,800 and 1000 between the 1st and 2nd coat of tung oil then used 0000 steel wool on the last two coats.
I used Minwax tung oil, and applied it with a sponge brush (like $.49 ea. at OSH) while it was hung up with a large paint stick at the neck joint.
Make sure to clean off all the sawdust and steel wool before and in between applying a coat of tung oil. I used mineral spirits. just a little dab or two on a shop towel( I used those blue ones,got it at Kragen's auto parts) was fine to do the whole body.
s540ltd
S470 Project - Neck Choice ian_dowling Other Ibanez Guitars (including Premiums) 2 06-30-2008 06:19 PM
project neck specs dimefan90 Other Ibanez Guitars (including Premiums) 0 04-18-2008 11:50 PM
Which neck for my project? Ad_Astra JEM and Universe Guitars 7 03-28-2008 12:20 PM
New Neck For Universe Project Mission1979 JEM and Universe Guitars 27 02-17-2007 12:09 AM
Ibanez Neck thru JEM project littlegreenman Classified Ads: Guitars and Gear 7 10-24-2005 07:37 PM
