Old 09-07-2003, 10:41 PM
Timanator  is offline
Posts: 343  -  iTrader: (0)
Project Strat problems.
I have decided to turn a Squire that I was given into a better Strat.
I refinished the body and reshaped the neck and electronics.
And ended up with a few strange problems.
1. When the TV is on it picks up alot of noises. (It now has stock Strat pickups at Neck and middle, and a Seymour Duncan Cool Rails) It is very nice and quiet when the TV is off.
2. The neck joint is very bulky and loose. It isnt near as solid and moves a bit when I exert pressure on it. Anyway I can reinforce the joint to be more solid and thin the neck joint down like the older JEM's?
3. Tuners are absolute crap. Can I just install Spertzel locking tuners on this without much mods?
Thanks.
Old 09-08-2003, 01:46 AM
keithb  is offline
Posts: 163  -  iTrader: (1)
Can't help with problems 2 and 3, but http://www.guitarnuts.com/ will show you how to make it as quiet as a mouse.
Old 09-08-2003, 12:13 PM
JimmyW  is offline
Suspension: Multiple Users
Posts: 254  -  iTrader: (0)
I say have a professional set it up....setting up guitars isnt for amatures
Old 09-08-2003, 01:51 PM
darren wilson  is offline
Posts: 4,190  -  iTrader: (0)
Setting up and wiring guitars is dead-easy if you're handy with a soldering iron, can follow a wiring schematic and have at least some idea of what you're doing.
I used to get a lot of RF interference with my Dean, because it has some long lengths of wire in it that were not shielded. The pickups are wired to push-pull pots, and then the output from those go to the selector switch, which is in the upper bout of the guitar, like a Les Paul, and then back to the output jack.
The Duncan pickup wires are nicely shielded, and the control cavity is already coated with graphite shielding paint and has an aluminum shield on the cover. But those long wires going up to the pickup selector (probably a couple of feet of wire total) were not shielded in any way.
A couple of feet of unshielded wire = one big antenna.
The noise and RF interference were intolerable at times, so i finally decided to rip out those long wires and replace them with 20- or 24-gauge shielded wire. It was hard to find... a few local Radio Shack stores did not carry any thin-gauge shielded wire for some reason, but i did eventually find a little electronic component shop that had some in stock. That did the trick. The guitar is eerily quiet now when i'm not playing.
Chances are, your Squier has little or no control cavity shielding, or your existing shielding is improperly grounded.
Upgrading your shielding is a good place to start. Shielding paint is good, but copper shielding tape is better. Put it inside the control cavities (around the pickup cavities too, if you like) and on the underside of the pickguard. Solder a wire from the shielding to the ground. A good place to connect the universal ground is on the back of one of the control pots, then a single wire to the ground on the output jack. That should pretty much do the trick. Don't forget to shield inside the output jack cavity.
Since all of your wiring will be contained in the control cavity, you probably won't need to upgrade to any shielded wiring. I only had to resort to that because i had wires that extended out beyond the shielded control cavity.
Old 09-08-2003, 03:39 PM
Tezifon  is offline
Posts: 106  -  iTrader: (0)
shim the sides of the neck pocket to prevent it from moving, use pieces of paper or tape
for the turners i think the sperzels are too expensive for that guitar, better go for gotoh standard turners, more affordable and good quality
Old 09-08-2003, 04:23 PM
Well I have made some headway.
1. I changed the wires I have used from Shielded Copper wires to regular shielded wires(Silvery looking) and now it is quiet even next to the TV.
2. Neck pocket is still getting a tiny bit of movement, not really anyways to shim it, as the neck joint is very tight from the factory.
3. Tuners are still crap. $60 is too much to spend on a set of tuners?
Old 05-12-2004, 02:05 PM
Tezifon  is offline
i readed a trick in another forum, used for the 3 screws old fenders, put a piece of metal web in the pocket, it will get in the wood by the tension and stop any movement
les paul, locking tuners, neck joint, pickup cavities, seymour duncan, strat pickups
