Tech: Setup, Repairs and Mods
Pros help me out with my rg550! I need to get rid of scarfs!
06-13-2004, 07:10 AM
jpwannabe
Posts: 358 - iTrader: (
Hi, All.
I bought a 90's RG550 a while ago and I want to make it look more refined as the original owner didn't really take good care of it. Some areas are badly scarfed and scratched, the front looks okay, nothing major that I'd mind too much, the back is a bit scratchy as well. The worst areas are inside the curves where the horns are. I really want to remove the scarfs as its very irratating seeing them. Its not to the wood. but the thing is I'm thinking I'll sand right through the clear into the paint becuase the scarfs does look pretty deep compared to normal scratchs. I took some photos to show everyone insde the horns.
Also what grade of sand paper would you suggest for me to start with,
I read on ProjectGuitar to start with 2000#, isn't that a bit thin? The scarfs are pretty rough and do look worse then the pics have shown.
I would also like some tips on how to do this, as this is my first time and I'm a complete newb. Is is possiable to only do parts of the body?
Or would I have to sand down the whole thing.
Also not sure which kind of polishing compund I should be using, are there anything thats cheaper and does the job?, the good stuff are pretty expensive.
Thanks , anything would be greatly appreciated.
here are links to pics,
http://community.webshots.com/user/shihku
its under the rg550
jpwannabe
Find all posts by jpwannabe
06-15-2004, 12:23 PM
jpwannabe
anyoen???
jpwannabe
06-15-2004, 12:24 PM
darren wilson
Posts: 4,190 - iTrader: (
What do you mean by 'scarfs'?
darren wilson
06-15-2004, 12:28 PM
Posts: 19,352 - iTrader: (
I imagine you means scratches because "scarf" doesn't relate.
If you try sanding through a deep scratch you'll also sand through the top layer of clearcoat and end up with fog/blend lines everywhere you go through it, which isn't going to look any better than the scratches. Sanding is only good for very light scratches that won't catch a fingernail, unless you're doing a refin.
06-15-2004, 02:10 PM
jpwannabe
sorry for my bad english,
so what should i be doing here do you think?
just leave it alone? or is anyways to fix this?
jpwannabe
06-15-2004, 02:30 PM
darren wilson
If you have bad scratches and scrapes that aren't down to the wood, sanding them will only make them look worse. If they really bother you that much, you could try filling them with CA glue (super-glue) and then sanding them smooth. Since the guitar is already beaten up, it might be a good opportunity to try fixing finish blemishes like this. It's not like you can make it look much worse.
While i like my guitars to look pretty pristine, i think wounds and battle scars that occur in the line of duty add character.
darren wilson
06-15-2004, 02:33 PM
I'd just polish it as is and not try anything too fancy. Taking the whiteish look out of the blems and making them shine again will go a long way to making it more acceptible.
06-15-2004, 03:04 PM
jpwannabe
battle scars I didn;t make dosen;t really count,
but i figured, I think i'll just leave the way it is and play hell out of it :P
jpwannabe
06-17-2004, 09:15 AM
Petie
Posts: 2,878 - iTrader: (
I think the word you're looking for is "scuff."
Petie
Visit Petie's homepage!
Find all posts by Petie
06-19-2004, 05:38 PM
jpwannabe
okay thats it, scuff,
thats it
thanks
jpwannabe
06-23-2004, 12:08 AM
CQ7String
Posts: 246 - iTrader: (
So, you have an RG550. It's getting a little old looking, paint's starting to chip and wear. You could get it painted, or you could harken back to the days of drooling at Vai in Guitar magazine with his burnt-look guitar.
When I was maybe 13, all I wanted was a Jem with a handle, because, well, it had a handle. And handles were cool. (I also wanted a pink one with neon pickups.. thank god I grew out of that).
Anyways, a little lighter fluid, some paint, plenty of beers and a $250 trip to the luthier for intonation and rewiring later, I have my own personalized 550BQ, fresh off the, erm, grille.
Pics do it poor justice, it actually looks (imho) pretty slick in person.
Probably not what you're looking to do... But just letting you know that "light it on fire" is always an option.
CQ7String
Visit CQ7String's homepage!
Find all posts by CQ7String
guitar mag
ibanez rg550 road flare red color code
what best ibanez rg550 rg 570
what guitar strings do the pros use
what tuners fit an RG550?
what pros use as their first Amps
11:18 AM
