Tech: Setup, Repairs and Mods
Push-pull coil tap or mini switches?
02-06-2008, 11:56 AM
shreddersymphony
Posts: 1,482 - iTrader: (
For my second
custom guitar
I've decided to go with two humbuckers w/ a single coil in the middle, and coil split the humbuckers. I know there's two ways of going about this: the push-pull pots/knobs, and
mini switches
. I think I am going to go with mini switches because I find it a little annoying to do the push-pull thing, because i always accidentally twirl the volume or tone knob or somethin'. What do you guys think? Here's the body, precarve:
shreddersymphony
Find all posts by shreddersymphony
02-06-2008, 12:54 PM
Jaden
Posts: 2,464 - iTrader: (
Re: Push-pull coil tap or mini switches?
mini switches suck - there is no way in the world they ever look good...
what about a push/push pot -
http://www.elderly.com/accessories/items/EP296.htm
Jaden
Visit Jaden's homepage!
Find all posts by Jaden
02-06-2008, 02:15 PM
shreddersymphony
mini switches look perfectly fine...tons of Carvins have em and stuff. And if you read my post at all you'll notice I said i specifically will likely avoid push-pull.
shreddersymphony
02-06-2008, 02:23 PM
Jaden
yep, and if youd read my post you would see that I read your post... and recommended push/push pots
if you like mini switches then buy them, I was merely offering an alternative to push/pull without adding any other switches...
Jaden
02-06-2008, 02:29 PM
shreddersymphony
No I know what you were recommending lol, its just that i specifically said that i dislike push-pull pots and was gonna go with mini switches, i was just wondering if besides those 2 there were any other options.
shreddersymphony
02-06-2008, 03:30 PM
bammbamm
Posts: 4,134 - iTrader: (
Why can't you just hard wire it into a 5 way like Ibanez or anyone else does?
If you're going for a
coil tap
on just one PUP at a time, I would say a single Pull pot on the tone knob would be more out of the way and not so likely to be a PITA to use.
bammbamm
Visit bammbamm's homepage!
Find all posts by bammbamm
02-06-2008, 04:24 PM
jb4674
Posts: 4,010 - iTrader: (
Reviews: 6
How about adding an extra pot that turns the
coil split
by turning the knob? Kind of like what PRS has as the pickup selector on some of their axes.
Jimmy
jb4674
Find all posts by jb4674
02-06-2008, 04:37 PM
TMatt142
Posts: 545 - iTrader: (
oooo that PUSH/PUSH pot looks like the way to go...Think I might check in to that a bit more....
TMatt142
Find all posts by TMatt142
02-06-2008, 05:20 PM
brothersnowgone
Posts: 1,498 - iTrader: (
Reviews: 7
I agree with the mini switches route, and they don't look bad! Definately a little easier to use in a live situation, especially if you need to make a quick change while your playing. It's always easier to flick a switch while you play then to pull up on a knob.
brothersnowgone
02-06-2008, 05:22 PM
shreddersymphony
Lol. Well it's a well known thing that push-
pull coil tap
is the way to go for extra tones and whatnot. I'll look into the knob turn thing as well.
shreddersymphony
02-06-2008, 06:49 PM
projectjem
Posts: 664 - iTrader: (
i like pulling my knob up on stage.
projectjem
Find all posts by projectjem
02-06-2008, 06:56 PM
jazzedout
Posts: 671 - iTrader: (
I prefer the cleaner look of a push/pull pot...
jazzedout
Find all posts by jazzedout
02-06-2008, 07:55 PM
DaniJem
Posts: 1,069 - iTrader: (
I like the miniswitch fot tapcoil... looks cool:
but in others guitars also I have push/pull on tone pot. and its the best way to not make holes in the body.
you choose.
DaniJem
Find all posts by DaniJem
02-06-2008, 08:12 PM
brothersnowgone
Reviews: 7
Sweet axes!
brothersnowgone
02-06-2008, 08:47 PM
Jemwielder
Posts: 1,000 - iTrader: (
Reviews: 6
I don't see the point in drilling an other hole in a nice piece of wood if you don't have to. I'd go with the push pulls. I've always found them easy to access while playing to change the tone of your guitar.
Jemwielder
Find all posts by Jemwielder
coil split
coil tap
custom guitar
mini switches
pull coil
pull coil tap
how to pinky pull up
push pull pots how they work
how to play heavy metal thru single coil?
how to replace single coil pickup cover
magnetic push button switches how they work
push pull pot wiring help
JohnnyRG1527
03:06 PM
WTT: Smokey Amp for D-tuna or Push pull pots
gemini8026
04:49 PM
wiring using push pull switch
Jeff - CRO
Pickups & wiring
04:28 PM
Push pull pots or mini switches?
stratman219
Pickups & wiring
05:03 PM
PRS blower push pull?????
aerocol
10:05 PM
05:41 AM
