Re: push pull pot wiring help
Using a push/pull for a kill switch would not be as handy as a toggle but the wiring is easy. Run a wire from the hot lug of the volume(or output jack) and a wire from ground(like the back of the volume pot) so when you pull the switch up, those 2 wires get shorted. Instant silence. Instead, I would pull the tone knob out and put a toggle in. If you actually use the tone knob, maybe use a push/pull to add in the cap for a treble rolloff?
