Old 05-09-2008, 08:09 PM
freedom's door  is offline
Posts: 433  -  iTrader: (1)
Putting a single coil in a humbucker slot
I have an RG with H-S-H pickup config, but i'd like to put a SC in the neck position. There is no pickguard, the pu's are direct mounted. Problem is that the width of a single coil is greater than the space where the HB screws into the guitar. I really don't want to have to route the guitar to fit the SC- does anyone have any suggestions or ideas?
Thanks in advance.
Old 05-09-2008, 08:12 PM
elcid  is offline
Posts: 8,720  -  iTrader: (12)
Re: Putting a single coil in a humbucker slot
Wire a humbucker as a single coil?
Someone used to make a pickup ring that would reduce a humbucker slot to single coil size, but that wont help much if your pickups are direct mounted.
Old 05-09-2008, 09:07 PM
Algiman  is offline
Posts: 2,553  -  iTrader: (14)
Humbuckers wired as singles are a poor compromise on tone.
I'd suggest a HB sized P90 - the Dimarzio bluesbucker for example or a BKP Mississippi Queen if you have the cash.
Old 05-10-2008, 10:24 AM
CityofBlindingLights  is offline
Posts: 563  -  iTrader: (0)
Humbucker from Hell
Old 05-10-2008, 11:18 AM
Matheau  is offline
Posts: 206  -  iTrader: (0)
It depends on how much wider it is, I would think. If you are willing to sacrifice the ability to raise or lower it easily, you could cut off the plastic edges where the screws go.
You may be able to get it to fit by tilting it a little bit, rather than putting it in straight as well.
Old 05-11-2008, 12:02 AM
Thanks for the replies- i was thinking that maybe i could route the plastic edges around the screws on the pickup just enough to make it fit. I'll have to actually get a pickup in my hands though to see how well this would actually work.
Old 05-12-2008, 10:06 PM
albee1952  is offline
Posts: 784  -  iTrader: (2)
If you don't have a hard preference, GFS makes some single coil pickups that are standard HB size and fit. I got one of *bay
Old 05-13-2008, 12:08 AM
AmazinAzian12  is offline
Posts: 549  -  iTrader: (0)
isnt a P90 a gun??
Old 05-13-2008, 12:56 AM
Axayacatl  is offline
Posts: 170  -  iTrader: (0)
aren't asians supposed to be smart?
Old 05-13-2008, 11:23 AM
jim777  is offline
You can definitely do that. This is one of the things you have to do to get replacement pickups into a Carvin 7 string. The plastic bottomed DiMarzio pickups are the easiest to dremel in my experience.
Another post like this and it will be your last here.
jim
Old 05-13-2008, 03:25 PM
-Rhaab  is offline
Posts: 479  -  iTrader: (0)
check out Seymour Duncan SHPR-1 P-Rails pickups imo, seem interesting
http://www.youtube.com/watch?v=fZhJXcSVnfs
Old 05-13-2008, 03:40 PM
toneboy  is offline
Posts: 1,665  -  iTrader: (2)
Originally Posted by CityofBlindingLights View Post
Humbucker from Hell
+ 0.5 I've got a HfH in one of my PGMs and it's similar to a single coil in some ways it's dissimilar in others. If you want a real single coil sound, get a real single coil.
Old 05-15-2008, 06:43 PM
Agent540  is offline
Posts: 1,073  -  iTrader: (0)
I 've just wired and tried a pair of P-rails on a SZ520 : they sound great, IMHO, in any position (Neck,Neck+Bridge,Bridge(Parallel, series, only P90(s), only rail(s)))
coil pickup, dimarzio pickup, dimarzio pickups, neck position, pickup ring, seymour duncan
Help! Pickup wiring issues. HSS - humbucker replacement Oatman Tech: Setup, Repairs and Mods 2 02-04-2008 03:38 PM
WTB: Jem Single Coil Act of God Classified Ads: Ibanez JEM/UV Guitars 2 08-09-2006 09:56 AM
possible for a single coil to go completely dead? swordofjoshua Pickups & wiring 2 04-15-2006 02:18 AM
7 strings, 2 hum + single coil ... i need an EMG solution! skattabrain Pickups & wiring 0 11-01-2004 10:53 PM
Replacement Single Coil for BFP? Dunadan Pickups & wiring 6 07-05-2004 12:22 AM
