Hi Rich. I was on the Ibanez site looking for the part number of the Edge
string lock blocks because I want to purchase a new set for an old Edge I have. Usually they have a nifty little picture to go with it when you hover over the part number so you don't order the wrong thing. Well this time none of the pics work. I would like to confirm the part number of the string lock blocks (the 6 little guys that squish the string and hold it in place after you chop off the ball end). The description is a little vague. Would that be the "block lock bar" 2LE2-17? The screws that fit into the blocks are fine and I assume they are part number 2LE2-18 (block lock screw).
Just want to make sure I order the right part. Thanks for your help.
