Old 05-03-2002, 06:30 PM
Triangle  is offline
Posts: 41  -  iTrader: (0)
Question for those who have shimmed their own necks
How hard was it? Was it successful on the first attempt? How tight do you make the neck screws?
Old 05-03-2002, 06:33 PM
yurich  is offline
Posts: 655  -  iTrader: (0)
I had to do it a few times..it's really easy. the hardest part was cutting the paper to the right dimensions
actually mine's not enough. you can actually see the shim from the side, but it's still not enough
Old 05-03-2002, 06:47 PM
yurich  is offline
speaking of too high, how do the famous guys get their action so high? I find that I play REALLY aggressively, I need at least 3mm. I could of course go to a thicker shim, but I figure I'll lose sustain considerably. Is there another way?
Old 05-03-2002, 07:00 PM
Rich  is offline
Posts: 19,356  -  iTrader: (21)
Who needs a shim for high, try raising the bridge!
Old 05-03-2002, 08:22 PM
yurich  is offline
the bridge is too high already the bottom of the base plate is almost inline with the body
how does Glen do it?
Old 05-03-2002, 08:28 PM
littlegreenman  is offline
Posts: 2,626  -  iTrader: (4)
are you shimming the neck at the bottom of the pocket? or the top? if it's at the bottom of the pocket (side closest to the bridge) you're lowering the action, if you're shimming on the top (side closest to the headstock) you'd be raising it. what I wanna know is, how can anyone play so hard you need 3mm action????? LOL
Anyway, as for the shim material, I like to use business cards, I generally cut them the full width of the pocket, and about 3/8" wide. Then, tighten the bolts as tight as if there was no shim in there. They have to be tight. If you need a thicker shim, add a second one, I had to add one the thickness of 2 cards in my UV7BK to get it right, not a big deal. Just don't leave the screws loose in the hopes that it will only take one shim!
Old 05-03-2002, 08:47 PM
yurich  is offline
I put it in the right place, but not right on the edge...here's a quick diagram:
| O | S| O |
| | H| |
| | I | |
| | M| |
| O | | O |
| |__| |
The shim is high enough for a medium-sized pick to get through there roughly 0.75mm
I just pulled the bridge to highest, I can get 3mm. It still buzzes. I'm sorry, but I just can't play Master Of Puppets soft
Old 05-03-2002, 08:50 PM
yurich  is offline
the thing messed up my diagram
anyway, it's right by the neck-side screws but between the two sets of screws, extending full-length. it's approx 1x5cm
Old 05-03-2002, 09:55 PM
BrianH  is offline
Posts: 599  -  iTrader: (0)
I'm not one who knows bunches about stuff like this. So whats the point here? The shim can help you get lower action without buzz? Is that the purpose?
Old 05-03-2002, 10:01 PM
yurich  is offline
you can shim to lower your action if the bridge won't go any lower.
likewise, it the bridge sits too high, you can shim the neck to a bigger angle
personally, I don't like my bridge too high. it's just not comfortable for the palm
Old 05-04-2002, 03:03 PM
Triangle  is offline
Well I shimmed my neck. I went from 2.3 to 2.0mm on the low side, and 2.0 to 1.7mm on high E. I was hoping to get it to 1.5mm, but It won't go there without fret buzz.
base plate, fret buzz, neck screws
