Tech: Setup, Repairs and Mods
Quickie on finish over paint
08-06-2007, 07:19 AM
CityofBlindingLights
Posts: 563 - iTrader: (
Could you just apply four coats or so of
tung oil
to a body that's been painted about six coats of standard paint?
Find all posts by CityofBlindingLights
08-06-2007, 07:34 AM
David McCarroll
Posts: 2,049 - iTrader: (
Re: Quickie on finish over paint
ummmmmm ..... to do what.......?
David McCarroll
Find all posts by David McCarroll
08-06-2007, 07:50 AM
Ki swordsman
Posts: 1,273 - iTrader: (
i think he means to replace the
clear coat
i guess it's possible with some finishing oils, but you only want to do it with the ones that have no tint to them as i'm pretty sure most oils can have a very slight yellow or brown tint hence why they still look great on wood
but your best bet for an easy cheap solution would be to go get some spraycan clearcoat and do it the semi-proper way
Ki swordsman
Find all posts by Ki swordsman
08-06-2007, 08:01 AM
Ki swordsman
i think he means to replace the clear coat..
Yeah, that's what I was guessing would be an easier option, don't want the yellowish tint (explained below)
Yeah, I guess I wasn't very clear. I was going to sand down a body and start from scratch, first with wood spirits then primer coat then color coats. I was hoping to do a white coat, so I'm thinking clear coat would be better as it wouldn't tint the white
08-06-2007, 08:11 AM
Ki swordsman
if you like, don't sand it all the way, just take a bit off and skip the woodspirits(i assume that's a sanding sealant) cos it'll already be sealed..
there's no need to take much of the paint off, especially if it's a floating bridge in which case no heights(like the bridge) can be altered no matter how many coats on coats..
with a
fixed bridge
- same deal but in certain cases with thick layers i guess you'd want to take extra off if you were cautious..
all you really need is to scuff sand it up for the paint..
Ki swordsman
08-06-2007, 08:40 AM
David McCarroll
Sorry about my flippant reply - I think you'd be best to follow the advice given by my countryman and do a foo foo can lacquer finish over the colour - most oils (and I am assuming Tung Oil also falls into this category) are penetrating finishes, and they aren't goint to penetrate far into several layers of coloured finish, which means they might never really dry, leaving you with a perpetually oily guitar.
The other thing to be a little careful of is clearcoat compatibility - make sure whatever you choose as a top coat is compatible with the colour under it - Kai is quite correct that the existing finish is the best undercoat going for your colour - grainfilled, smooth, flat etc - scuff sand and paint away!
David McCarroll
08-06-2007, 12:23 PM
andy7jem
Posts: 6,504 - iTrader: (
That title sounds SO wrong!!!!
It's only a guitar
andy7jem
Find all posts by andy7jem
08-06-2007, 07:32 PM
Ki swordsman
David McCarroll
foo foo can lacquer finish..
haha good term
Andy- guitars are often called sexy........... so it's only logical......
Ki swordsman
clear coat
david mccarroll
fixed bridge
tung oil
what people think texture finish rg2570
how to custom paint a swirl finish on a guitar
What brand of oil based paint is best for swirling a guitars paint job
how to multi colour paint your guitar
how to repair an ibanez jem 90 ham finish
Swirl Materials and Techniques.
jkahrs
116
02-27-2010
10:05 AM
Swirl paint to finish job
hollow125
09:28 AM
Using chemical to strip paint
TWJ
11:43 PM
JS90HAM - What paint finish is it ?
6828
08:58 PM
Guitar painting probs. - please help?
Scoff X
03:42 PM
06:05 PM
