Tech: Setup, Repairs and Mods
Re-stringing an Edge-equipped RG - I Need Help!
08-20-2007, 10:21 PM
JeffWiredBeck24
Posts: 181 - iTrader: (
I have some questions before I do this. I've heard from some that I should leave the nut unlocked overnight after tuning and stretching, so I? What does this do? Also, let me make sure my procedure is okay, I looked on Rich's site for some help too.
-Re-string one at a time, from high E to low E.
-Tune/heavily stretch high E, then put B on.
-Repeat until all strings are on and are at perfect pitch.
-After they're all FULLY stretched and in perfect pitch, tighten the nuts, and give the trem a real workout.
-Unlock nuts, tune to pitch again using pegs.
-Tighten nuts, fine-tune until it stays at perfect pitch.
-Plug in and play.
I know I seem a bit anal but I don't want to screw this up, and I want the tuning stability to be great and I want the trem to return to perfect pitch all the time. Any help is appreciated. Thanks.
JeffWiredBeck24
Find all posts by JeffWiredBeck24
08-20-2007, 10:25 PM
Posts: 19,344 - iTrader: (
Re: Re-stringing an Edge-equipped RG - I Need Help!
Heavy stretch the high E will just break it, heavy stretch the low E.
08-20-2007, 10:26 PM
screamndemon69
Posts: 5,676 - iTrader: (
screamndemon69
Find all posts by screamndemon69
08-20-2007, 10:31 PM
JeffWiredBeck24
^Right, I'll just stretch it until it can be stretched with no drop in pitch. How are the steps? Anything different I should do?
EDIT: screamendemon, thanks. I've looked at that and read it over a few times. I just want to confirm the steps I'm taking beore I do it.
JeffWiredBeck24
08-20-2007, 10:39 PM
arnoroth661
Posts: 61 - iTrader: (
JeffWiredBeck24
^I just want to confirm the steps I'm taking beore I do it.
Patience is a virtue with
floating tremolo
-equiped guitars.
arnoroth661
Find all posts by arnoroth661
08-21-2007, 12:13 AM
JeffWiredBeck24
arnoroth661
Patience is a virtue with floating tremolo-equiped guitars.
Yes, hopefully listening to Liquid Tension Experiment will lessen the tediousness. But anyway, I want to confirm that the steps I listed above are all good and that I'm not missing anything.
JeffWiredBeck24
08-21-2007, 02:09 AM
JeffWiredBeck24
One final question: after the strings are fully stretched and the guitar is in perfect pitch (before the locking the nuts), should I leave the nuts unlocked overnight? Or should I just go ahead with the fine-tuning?
JeffWiredBeck24
08-21-2007, 02:24 AM
Would be considered a wives tale but wives are usually much smatter than that!
08-21-2007, 02:51 AM
David McCarroll
Posts: 2,049 - iTrader: (
JeffWiredBeck24
Can't honestly see what difference this would make.....
David McCarroll
Find all posts by David McCarroll
08-21-2007, 02:56 AM
JeffWiredBeck24
^All right thanks guys. I just read (on this site actually) that leaving them unlocked overnight makes a difference, I'll just go ahead with the fine-tune.
JeffWiredBeck24
floating tremolo
lock nut
how is the edge zero?
how do you tune a edge zero equipped guitar
is my edge trem bar in all the way
TRADE RG 350DX for Edge Pro Bridge or prestige neck!!!
hachimako
03:36 PM
FS: Fernandes Sustainer, RG Wizard Neck, Edge Trem, and lots more!
parker_fly
31
06-19-2006
08:13 PM
Stringing a Edge Pro
phil27
04:11 AM
rg 1550- edge pro going out of tune, need help
evil_k666
12:25 PM
06:45 AM
