Old 04-30-2008, 10:44 PM
wh15p3r  is offline
Posts: 13  -  iTrader: (0)
Recessed Edge
Okay, quick quick QUICK question...
I bought some plans from Guitarplansunlimited and he said he couldn't find any info on recessing the bridge so we just raised the fingerboard...
BUT!
I have decided to atleast try recess it, if it goes bung i'll sell the edge and put in an OFR or something similar.
In the plans my body was 1 3/4" and the fingerboard was 1/2" above the guitar.
Right now I have a 1/4" fingerboard and the neck is flush with the body, which is now 2"
If I recess the bridge 1/4", it would be the same as having a 1/2" fingerboard, Right?
Cheers
Old 05-01-2008, 10:29 PM
ryanb  is offline
Posts: 1,457  -  iTrader: (0)
Re: Recessed Edge
Those plans sound a lot out of whack to me. 1 3/4" is a standard body thickness and you don't need anywhere near 1/2" above the body for an Edge, even with no neck angle. And you could always add a bit of neck angle if you needed more room. Draw it out full scale and check the dimensions -- that's the only way you will know for sure. Never trust a template you buy online -- I haven't seen one yet that was accurate.
Old 05-02-2008, 01:02 AM
albee1952  is offline
Posts: 784  -  iTrader: (2)
Re: Recessed Edge
stewmac.com has a template for recessed floyds and I have used it for Edge bridges with success. Its all in how you place the template on the body but it can be done by someone with some patience and skill(and the right tools).
edge bridge, neck angle
Can I use Edge posts with an Edge Pro?? PatrickSimsCustomShopUSA Tech: Setup, Repairs and Mods 8 10-26-2006 11:00 AM
String spacing of Edge/Lo-Pro vs Edge Pro MetalZone J-Custom, USA Custom & Prestige Ibanez Guitars 21 10-24-2006 08:59 AM
Edge III Mystery... Solved? eclecticmage Tech: Setup, Repairs and Mods 47 10-22-2006 01:08 PM
Non Recessed Edge Trem smc Tech: Setup, Repairs and Mods 6 07-11-2006 02:10 PM
recessed edge pro bridge.. gn86 Other Ibanez Guitars (including Premiums) 10 01-31-2004 07:07 AM
