Old 11-24-2008, 03:11 PM
Jacob K  is offline
Posts: 183  -  iTrader: (0)
Removal of excessive crud?
Hi all.
I just got myself a 89' 540P-II which seems like it has never ever been cleaned before. Behold the crud:
I am using Rich's cleaning guide, and by using a base for warhammer miniatures, I've killed the worst crud. However, there is still long way to go:
I wonder: Will my 0000 steelwool be enough to do the job (especially on the edges of the frets), or should I look into some nasty chemicals before I get busy with the steelwool?
Also, is linseed oil a decent oil to apply to a fretboard, or should I hold my horses and get some specially made stuff?
Thanks in advance.
EDIT: Should I watch out when steelwooling around the sharktooths?
EDIT2: The reason why I'm asking is because the fingerboard has some deep pores, and they are of course filled with crust. I wonder if I should steelwool all the way into the first level of pores which hold this crust in order to get it cleaned properly, or leave a little tiny bit of crust to be gentle on the fretboard (and for good luck).
Old 11-24-2008, 04:41 PM
Ayrton  is offline
Re: Removal of excessive crud?
Use an old toothbrush and scrub with the grain.
Old 11-24-2008, 05:05 PM
moebius  is offline
Posts: 2,041  -  iTrader: (0)
If you do use steel wool, either remove the neck or tape up your pickups cause those things are like magnets to steel wool .
Old 11-24-2008, 05:55 PM
Jacob K  is offline
Ayrton: Unfortunatly, that doesn't seem to be able to deal with really nasty crud - it's fine for removing steelwool, though.
moebius: Whoa, thanks man! Has to be the most work-saving tip I've had today, I taped my pickups within an instant of reading it. Phew.
Old 11-24-2008, 06:47 PM
michblanch  is offline
Posts: 1,159  -  iTrader: (4)
I use Synthetic fine steel wool.
Rub with the grain, then oil and wipe down (I use wonderwipes with lemonoil.)
Then I wipe with the wool again. Then another wiping with Wonderwipes, let it dry to a haze, then wipe off.
GuitarBizarre  is online
Posts: 1,184  -  iTrader: (0)
Psst... thats because they're magnets...
Old 11-24-2008, 07:06 PM
Ayrton  is offline
Try using a stiffer brush, or cut down the bristles to make them stiffer.
Old 11-24-2008, 07:11 PM
Rich  is offline
Use the edge of a pick to get all the heavy stuff off. The rest will soften with oil and just wipe off.
Never continually steel wool a fretbord to clean it, unless you want a scalloped board at some point.
Never do it on the guitar without some serious masking, in fact, just don't do it on the guitar if you do.
Old 11-24-2008, 07:24 PM
Jacob K  is offline
Whoa, I've been just about to cause a minor catastrophe on myself then, it seems.
I had the idea that the crud would just mix with the oil and sink into the wood, but apparantly I was wrong.
I already spent a lot of energy on rubbing the board, but mostly with a pick/piece of plastic, so the harm is very limited. And luckily, it seems that this was also the first time it ever happened to the guitar, so I guess it can take it just for once.
Seems like I misunderstood the purpose of steelwooling in your Grunge-off, Rich, thanks for putting it straight to me.
I guess I'll just pop to bed and let the guitar rest so that I can wake up to get some good oil tomorrow. Cheers to you all.
Old 11-24-2008, 07:32 PM
Rich  is offline
Steel wool is to even the board color and sheen out for visual gratification only.
Old 11-24-2008, 07:47 PM
Jacob K  is offline
Oh well, in that case I'm gonna have a pretty visually gratificating fretboard
Old 11-24-2008, 08:37 PM
Here watch this.
When he says oil soap, he means Murphys Oil.
http://www.youtube.com/watch?v=24yWr2LRmJY
Old 11-25-2008, 10:34 AM
moebius  is offline
Thus the smiley face .
Old 11-25-2008, 12:33 PM
I know :P
Old 11-25-2008, 02:06 PM
moebius  is offline
I know :P
Ahh good man!
crud, fretboard cleaning, neck cleaning, rosewood neck cleaning
Wall hangers leaving crud on my neck eruji Gear and Equipment 9 09-12-2008 01:14 PM
FTLOG... good or crud? Davey Polls 65 09-17-2006 01:24 PM
Excessive wear of flat blade? UV JEM and Universe Guitars 15 07-27-2004 10:15 PM
CRUD!!! HELP! Scoff X Tech: Setup, Repairs and Mods 19 03-12-2003 11:15 PM
Excessive string breakage...HELP!!! - On my Lo-Pro equipped Patrick Deno JEM and Universe Guitars 14 06-17-2001 06:39 PM
