Tech: Setup, Repairs and Mods
Removing neck dot inlays
03-02-2008, 05:27 AM
ANT5150
Posts: 163 - iTrader: (
Can anyone help with a tutorial on the safe way to remove neck
dot inlays
. I want to remove them from the neck and fill them in to leave the neck blank.
ANT5150
Find all posts by ANT5150
03-02-2008, 05:38 AM
Jaden
Posts: 2,464 - iTrader: (
Re: Removing neck dot inlays
by far the easiest way is to buy a set of matched drill bits and plug cutters.
drill out the dots using a 6mm bit - or maybe larger depending on the size of your dots and then taking a piece of timber of the same type, cut a matched plug using your plug cutter - glue in and sand level... job done
http://www.axminster.co.uk/category-...ugs-207896.htm
05:42 AM
. Reason: add link
Jaden
Visit Jaden's homepage!
Find all posts by Jaden
03-02-2008, 05:58 AM
ANT5150
I was thinking of using wood filler. Would you recommend this?
ANT5150
03-02-2008, 06:21 AM
Jaden
no, not if you wanted a good job...
although it could depend on your
fingerboard wood
... what is it ?
rosewood would show filler up to the extent that you may as well have not removed the dots - the filler will stand out a mile...
if its ebony, then you could get away with it possibly by blacking the board afterwards..
maple... no chance
Jaden
03-02-2008, 06:43 AM
ANT5150
It is rosewood.
ANT5150
03-02-2008, 07:09 AM
Jaden
well, if I were doing it for a customer, I wouldnt be able to live with myself if I used filler, even around a proper plug... it would keep me awake at night
I would use a piece of scrap rosewood to cut the plugs and do my best to match the grain.. to ensure a perfect fit you can also cut the plug oversize and sand a taper on it before gluing it in and paring the excess away with a [very] sharp chisel.
Jaden
03-02-2008, 08:54 AM
TAorama
Posts: 1,762 - iTrader: (
You should consider just replacing the fretboard if you want to do away with your inlays. I have yet to see a dot replacement that didn't look like crap, or wasn't at least totally obvious. Especially on rosewood. I agree with Jaden - if you HAVE to do it, use plugs, not filler.
TAorama
Find all posts by TAorama
dot inlay
dot inlays
fingerboard wood
parker are they neck thru
how to led inlays
removing snare from overheads
why is through neck construction expensive to produce?
how do you put the strings closer to the neck on a ZR tremalo
Damaged Neck Screw Holes On My Body
Eddie_V_H
04:03 AM
FS RG550 body & neck, RG570 neck & misc
screamndemon69
01:58 PM
removing the neck
dc_mally
06:48 AM
Do I need a neck shim?
giannifive
04:39 PM
Removing the neck finish - Do I have to remove the lo pro ??
BronzeMan
05:16 PM
01:15 PM
