Old 03-11-2008, 07:29 PM
Vaistarr  is offline
Posts: 12  -  iTrader: (0)
Replace Edge Pro With Edge/ Lo-pro Edge Trem
Hi folks , I'm French and new on Jemsite, that is for me the best Web site about ibanez Guitars
So I would like to put a Edge or Lo-pro Edge on my JEM77B RMR " Bah horsie" , but it looks like the Edge an Lo-Pro don't fit the post-2003 JEMs.
But i Don't understand Why it couldn't , because the Trem routing of the Body does not seem to have Changed since The first JEM (with Lion claws) was built , but maybe I'm Wrong ?
Could somebody help me for this problem , because I'm just fully scared about routing the Mirror finish..
Why I wan't to replace the Trem is because the guitar doesn't stay in tune when I Dive the bar ( like if the Springs were not powerful enough to exactly put the trem to the original position) , but this problem appeared 4 month ago, and i didn't have the problem when I bought the guitar.
So I really Need Help. I just cannot believe that Ibanez installed those F*****G Trems on such an expensive Guitar ( but also a dream !!) 2700€ in France ...
Thanks
P.S: Please Forgive my English! Proud to join Jemsite community !!
Last edited by Vaistarr; 03-11-2008 at 07:33 PM. Reason: mistake into a sentence , necessary for comprehnsion ;)
Old 03-11-2008, 07:35 PM
Rich  is online
Posts: 19,354  -  iTrader: (21)
Re: Replace Edge Pro With Edge/ Lo-pro Edge Trem
A new trem won't fix the problem. Fix the problem, and if you still want a new trem then ask again.
http://www.ibanezrules.com/tech/setu..._stability.htm
Old 03-11-2008, 08:03 PM
losgatosrg350dx  is offline
Posts: 848  -  iTrader: (0)
it could be anything, ur trem post's could be worn and the angles could be shifting the balance on the bridge.....maybe get ur guitar setup, new back springs, new trem post's, new base plate for the trem...where the fulcrum plate is
other than that....are you good with a dremel... and a sharp chissel??
Old 03-16-2008, 03:14 PM
Vaistarr  is offline
Thanks for answering!
My trem post are in good condition , and ared used. My seller also Told me that it could be the nut , but I think not. The trem angle is good !
But i ve read on many sites that Edge Pro bridges weren't really good.. Can somebody confirm or contest this affirmation?
RICH , i tried to read your "Tuning stability tutorial on IBZ rules ,, but my english level doesn't allow me to understand everything... I'll see with a friend to give you more information.
Nevertheless , can I fit an Original Floyd rose on the jem , instead of installing an EDGE / Lo-Pro EDGE ??
Thx. See Ya !
Old 03-16-2008, 08:30 PM
Rich  is online
It's very doubtful the trem is your problem.
Old 03-17-2008, 09:55 AM
jb4674  is offline
Posts: 4,010  -  iTrader: (0)
Reviews: 6
Without seeing the guitar, I'd say that your guitar would be a prime candidate for the stud lock mod and for some chapstick, along with stretching the strings properly.
Jimmy
Old 03-26-2008, 03:57 PM
Vaistarr  is offline
Jimmy
Yes I've read a topic about the trem post and studs mod kit that i could order on Cottam Guittars.com (or IBZ rules.com) Is this modification really working ? ANd sorry for my english ignorance ( babelfish couldn't help me) but What does " chapstiks" means ?
Thanks for all your ANSWERS Friends
Old 03-26-2008, 05:03 PM
jb4674  is offline
Reviews: 6
Chapstick is lip balm, or some product that you can purchase at a beauty store to treat dry, chapped lips (hence the "chapstick" name).
The stud lock mod works without question. Ibanez simply decided to not put it into their guitars to cut costs and people have been upset about it ever since. The mod allows for the studs to lock in place and prevent any movement when you're using the trem.
Jimmy
Old 03-26-2008, 05:23 PM
DarthLamer  is offline
Posts: 108  -  iTrader: (0)
Jimmy
Unless you can provide evidence proving otherwise, I believe at best this is an assumption.
Old 03-26-2008, 05:33 PM
jb4674  is offline
Reviews: 6
Search the forums for your answer or call Rich and he'll tell you
Jimmy
Old 03-26-2008, 05:39 PM
Rich  is online
Try and discredit all you want, it has been extensively tested by me and quite a few other perfectionst minded players.
The NEW cosmo studs are a much better fit, the slop has been cut down dramatically, but IMO it's because of the way they're spraying a paint rim onto the inside of the inserts, and I seriously wonder how long that will last before it disintegrates.
Old 03-26-2008, 11:09 PM
toshiro  is offline
Posts: 1,812  -  iTrader: (11)
Have you contributed anything to this forum besides posts like this? Oh, how I love ignore.
Old 03-27-2008, 01:05 AM
Look again, my previous post pertained to the assumption that Ibanez was no longer utilizing the locking studs, due to cutting costs.
baaaAAAaaaa!!!!
Old 03-27-2008, 01:11 AM
Rich  is online
It goes without saying they eliminated them to cut costs, and there is plenty of evidence if you knew what you were talking about
Old 03-27-2008, 01:24 AM
Mind directing me to a non-biased source that mentions the reasoning behind Ibanez's decision to stop manufacturing the locking studs?
base plate, floyd rose, ibanez guitars, locking stud, locking studs, pro edge, retainer bar
Can you replace an edge trem with a LoPro Edge? - Is it poss Cycovision Tech: Setup, Repairs and Mods 7 05-16-2009 01:22 AM
RG470 Edge Trem conversion LonePhantom Tech: Setup, Repairs and Mods 29 07-11-2006 12:35 AM
Questions about setting up my Edge Pro trem billyboy Tech: Setup, Repairs and Mods 7 04-05-2006 09:55 PM
FT: Black Cosmo Lo-Pro Edge Trem for your Chrome Lo-Pro or Original Edge Trem parker_fly Classified Ads: Guitars and Gear 4 02-19-2005 04:18 PM
Will another trem fit the Edge cavity? - Edges are scarce an darren wilson Tech: Setup, Repairs and Mods 2 08-09-2001 11:08 AM
